Tool Talk Discussion Forum
15 inch Disc sander adhesive?? what to use
Dave2pa
03-15-2006 18:05:57
does anyone have any recomendations of the type of adhesives to use on cloth backed 15 disc onto a steel disc?? will the spray on type used for auto-body repair work on this larger disc?? the smaller ones for auto body work uses a paperback , and these larger ones are cloth back Dave Thanks
BigMarv1085
03-17-2006 16:27:26
 Re: 15 inch Disc sander adhesive?? what to use in reply to Dave2pa, 03-15-2006 18:05:57
3M makes a product called 1357. Its brushable, brush on the metal, when it gets tacky, apply the sanding disc. When you change disc again, pull off and scrape the old residue with a razor blade.
Joe(TX)
03-17-2006 05:53:58
Like Vern said, use the 3M or similar disc adhesive. You can get it at any place that sells auto body refinish supplies. You don"t have to do a lot of cleanup when changing discs and the disc comes off easily.
Vern-MI
03-16-2006 12:43:15
3M Disc Adhesive. It comes in both spray and brush on and doesn't build up after repeated disc replacements.
ScottP
03-16-2006 11:13:50
Dave
We buy the discs that have the adhesive on them already.
Check McMaster-Carr.
Scott
souNdguy
03-16-2006 07:00:04
disc brake adhesive.. om.. spray on trim adhesive (3m)..uh.. spray on contact cement... Probably have to use naptha or even laqure thinner to get that stuff off..
soundguy
