Tool Talk Discussion Forum
Broken Drill Bit
Tom 671
03-15-2006 11:23:32
Now what do I do? I broke a drill bit in the hole and now I can not get through the metal. I ruined 4 other bits trying to countinue on drilling. It make a awful noise trying to drill with the other bit broken in the metal. Any advise would be greatful.
Thanks
Larry Condon
03-16-2006 05:48:05
 Re: Broken Drill Bit in reply to Tom 671, 03-15-2006 11:23:32
Last resort,throw the piece away and start over.
Tom 671
03-15-2006 14:03:39
Thanks for the information. Now I can continue my project.
Hermit
03-15-2006 14:01:54
Can you finish drilling the hole from the other side? Then punch out the broken bit after the holes meet.
JT
03-15-2006 13:12:15
If you broke it off in cast iron, you can take a torch, heat the bit and take the temper out of the bit. Or if you have an air custoff tool, you can put a masonry bit, put it on the air cut off tool, and use very high speed, this will drill it out, have drilled out broken easy outs that way
Broomstacker
03-15-2006 12:08:33
You can't drill thru a pc of broken drill with another hi-speed steel bit. Some times you can get all of the broken pieces out with a hammer and a punch--the material is brittle. If not, you may be able to get thru it with a carbide bit or a carbide end mill--not using much pressure, 'cause the carbide is even more brittle! Last choice (expensive, but sure) is to have it EDM'd out.
lucasss
03-15-2006 13:09:49
 Re: Broken Drill Bit in reply to Broomstacker, 03-15-2006 12:08:33
if you can get it upside down,heat the bit till red and then hit the oxy and burn it out.lucas
