Tool Talk Discussion Forum
lathe
Ken in Mich
03-13-2006 14:48:38
Been looking for a used or maybe new lathe, I see some are advertised as "engine" lathes. What does this mean?
benny2
03-13-2006 20:40:52
 A True Engine lathe is Re: lathe in reply to Ken in Mich, 03-13-2006 14:48:38
A True Engine lathe is "ANY" metal turning lathe, that is capable of cutting screw threads with a single point cutting tool using an attached slectable differential gearbox "screw engine" for that purpose. Which may or may not be quick change type. It refers to NO other feature than the screw threading.
MikeCatthemuseum
03-13-2006 21:36:06
 Re: A True Engine lathe is Re: lathe in reply to benny2, 03-13-2006 20:40:52
Bingo Ken. Second operation, Chuckers, etc... have no leadscrew. Most of the typical metal lathes you will run across are going to be engine lathes.
Speed and accessories also has nothing to do with toolroom lathes. A toolroom lathe has reverse to leadscrew, so it can thread without reference to a thread dial. Hendey lathes are good examples of this.
Tim Casbolt
03-13-2006 19:25:35
I looked at a lot of used lathes before I settled on a new Enco. Yea, I know, it's made in China, and I don't like that part. But I was looking at Hardinge toolmaker's lathes, along with numerous others such as Sheldon, South Bend, Lablonde Clausing and others, but couldn't swing the bucks for what you get. Also, the type of work I do most often requires slower speeds than a toolmaker's lathe is capable of. My Enco is a 14 x 36 with 18 speeds ranging from 60 to about 1800 rpm. You can feed with the threading pyramid (which comes with inch and metric, by the way) so there is always a speed that will give the desired finish. It comes with a Baldor motor which is made in the USA, and an Accurite (also USA) digital readout. I opted for the 5c collet attachment which allows me to do production work easily. It was 1/4 the cost of a used toolmaker's lathe with more features that I need for my type of work. At least half of what I do is in metric, so the digital readout is great because all you do is push a button and change from inches to millimeters.
Midwest redneck
03-14-2006 02:45:09
 Re: lathe in reply to Tim Casbolt, 03-13-2006 19:25:35
What did you pay for that Chinese lathe?
Eric in IL
03-13-2006 15:52:42
"Engine" lathe just refers to the lathe type. This type is typically found in job shops, school shops, and toolrooms. They are not intended for production runs. Other types of lathes would be Turret, Single and Multiple spindle automatic, Tracer, and Numerically Controlled.
The engine lathe is probably what you are after if you are a hobbist or do-it-yourselfer.
FC Andy
03-13-2006 15:39:13
An Engine lathe is just the proper name for a lathe. The type with the gap near the chuck that Garfield refers to is known as a Gap Bed (Engine)lathe if my understandings are correct from my days in vo-tech.
Garfield
03-13-2006 15:12:59
As far as I know an "engine lathe" has a removable section of bed under the chuck. This allow the machinest to swing large pieces close to the head of the lathe.
Ken in Mich
03-14-2006 14:33:12
 Re: lathe in reply to Garfield , 03-13-2006 15:12:59
Thanks for the replys Guys
