Tool Talk Discussion Forum
ot chevy auto transmission
dale r
03-13-2006 06:02:57
i am having a problem with the auto transmission in my 2000 chevy s10 truck. at first everything is fine . after 30 minutes or so of highway driving it will shift out of overdrive and i think the converter also unlocks. if i stop the truck and kill the motor, start off again it will work ok for a while and then do it again. can anyone tell me how to test to see what might be wrong.
thanks dale
lucasss
03-14-2006 08:49:17
 Re: ot chevy auto transmission in reply to dale r, 03-13-2006 06:02:57
mr transmission will scan if for free.
jdemaris
03-14-2006 06:01:37
When you say it shifts out of overdrive, what exactly are you calling "overdrive?" The typical GM auto-trans. has four speeds forward plus the lock-up converter that, when it engages, feels and acts like a 5th gear. Are you loosing the "5th", or are you loosing 4th and 5th? The converter is hooked to your brake-light switch, so it unhooks whenever the brake lights come on.
sjh
03-13-2006 15:50:10
How long since you changed your fuel filter. A plugged filter will do strange things. Low pressure in a fuel line some times it will act like the trany. I had a similer problem with a 95 blazer. It acted like the trany was slipping. Changed the filter and solved the problem.
bradk
03-13-2006 06:35:54
Dale,
The first thing to do is to have a shop or a select parts store pull any codes stored.Until then,it's a guessing game.~brad
