Tool Talk Discussion Forum
Trailer Widening
Hauler
03-12-2006 18:45:54
I expect most of you are like me in that when you fabricate something it ends up much more heavy duty than necessary. I have a 12,000# rated deckover tandem trailer that is 6.5' wide. I have been scheeming how to widen it out for some time. I've decided on L-shaped gussets bolted to the frame. The gussets would be 11" long(frame is presently 1.5" in from edge). Questions: I was figuring on 2" angle iron. Would 1/8" be heavy enough? I would like to simply weld them into 90 degree angles without welding a third side making the gusset a triangle shape. Also, how far apart would you space each gusset? The decking will be 2" pine. The added width probably shouldn't see a lot of weight, but who knows. The existing deck is white oak. This post is a little wordy. Hopefully I've made sense. Thanks, Hauler
ScottP
03-13-2006 11:39:25
 Re: Trailer Widening in reply to Hauler, 03-12-2006 18:45:54
Hauler
"The added width probably shouldn't see alot of weight, but who knows."
Because of who knows I would use either 3/16" or 1/4" angle. I would also add a 3/16"x 1 flat bar gusset.
With 1/8" I would put them every foot, 3/16" every 1.5 foot and 1/4" every 2 foot, and that is with a flat bar gusset.
But thats just me.
Scott
