Tool Talk Discussion Forum
O.T. Buick Coolant Leak
IA Roy
03-07-2006 07:33:51
Sometime back I was asking about where the possible places coolant could leak on the Buick 3800 in my son's 91 Park Ave could be, as it wasn't leaving puddles. I was all set to take off the intake manifold and I crawled under it and found that the water pump was leaking. I replaced it and that was the end of the leak. It had me puzzled as it wasn't leaving a puddle, but am telling you this as it saved me quite a bit of work and money to fully analyze it.
souNdguy
03-07-2006 08:26:21
 Re: O.T. Buick Coolant Leak in reply to IA Roy, 03-07-2006 07:33:51
bearing loose, seal is going.. but still holding. When hot.. there is enough pressure to leak.. when cool.. seal may hold.. no puddles... but does leak when car is running.. thus drips all your coolant out on the road thru pee hole...
Soundguy
