Tool Talk Discussion Forum
Log fence - how to?
hayray
03-07-2006 05:37:50
What are some different ideas of using pole sized and smaller timbers to attatch on post for log fencing? Making a cattle catch pen way out in the pasture. Any luck preserving post by burning them with oil?
Thanks, Ray
Mike Burdick
03-08-2006 17:15:12
 Re: Log fence - how to? in reply to hayray, 03-07-2006 05:37:50
third party image
Ray,
I would imagine there are as many ways to fasten poles to posts as there are people - this is how I've been doing it for the last 50 years. I use annealed wire around 8 gauge and wrap it once around post and pole and tighten by "twisting" the wire using a vise grip pliers or a fence tool. A hammer can be used to form the wire to the post while twisting the wire. I then put one fence staple over the wire on the post to hold it in position if necessary. This way one can go back and tighten the poles up again later if needed. I also take a few seconds and take the twisted ends and loop them back so it won't poke people or animals.
If you use this method make sure to use ANNEALED wire as it is easy to work with and will take the twisting necessary to tighten the poles to the posts. I get the wire from a steel supply, but farm supply stores also carry it around where I live.
hayray
03-08-2006 19:14:34
 Re: Log fence - how to? in reply to Mike Burdick, 03-08-2006 17:15:12
thanks for the picture and description, that is great.
Ray
Mike Burdick
03-08-2006 19:07:04
Oops! I can't edit my post...should have said 9 gauge wire.
J.C.H.
03-07-2006 11:46:34
Back in the days of real Ranching,before Helo's,Quads and Hummers to patrol Pastures,when a large supply of 5"-7" Timber was available the builder would cut timber in about 12' lengths ,then he would sink two poles about 8" apart and about 10' away he would repeat this two Poles side by side about 8" apart deal until the Corral was layed out and then he would stack poles horizontal from pole set to pole set.In other words the first set was laid down then the next to the right and left were laid on top with about 20" of the butt ends of these laying on top of the butt ends of the first row then continue building around the corral and up to the top of the fence line. You end up with a 6" about space between the horizontal poles. Gates were a number of individual Poles which slid across into this space that was created in the fence building. On another note, Here in Arizona the old timers built fence using Ocotilla Branches. They would cut the branches in 6' lengths and plant them side by side , this was done mostly in the Rain season if one occured. In a short time you had a living fence which was very formidable.Some wove Barbed Wire in to the Branches as it was planted. Almost nothing could penetrate one of these Fences except a Snake or Javellina maybe.
hayray
03-08-2006 19:17:41
 Re: Log fence - how to? in reply to J.C.H., 03-07-2006 11:46:34
thanks JCH
I may try that method on some parts of the corral where I need a solid wall.
thanks, Ray
