Tap drill sizes
Brian G
02-25-2001 15:27:38
Does anybody else use this "quick and dirty" method of determining drill size for taps? Find a drill that will just fit thru a nut of the same size and thread of the tap you're using. Unless I'm doing some "fine" work where it might really matter, this system works just fine.
Alberta Mike
02-26-2001 13:47:26
 Re: tap drill sizes in reply to Brian G, 02-25-2001 15:27:38
Some interesting stuff here (although I must admit that some of the math seems a bit involved). Meanwhile, I've noticed that the charts that have been mentioned refer to the fractional, numbered, or lettered drills, BUT when I buy a tap (say one in a blister pack) it always refers only to the fractional inch size and never to the more exact one which is usually lettered or numbered. Last week I bought a 6-32 tap for a carb application and it referred to a fractional inch size slightly bigger than the chart. I guess it's close enough right?
wayne
02-26-2001 06:56:03
hey brian
I`m wayne as a machinist i usually use a chart because they are readily available
but if you don`t have one and you have a calculater you can use this
major dia. - (0.6495 * pitch)
pitch = 1/number of threads eg 5/8 - 11 - unc
11 is the number of threads
1 / 11 = pitch
=0.0909
so then 5/8 - 0.0909 = 0.534
or 17/32
hope this helps
Paul J. Decker
02-26-2001 02:55:36
There may be times when the thread you're tapping is a special and is not on a chart. The following formula works for all sizes and pitches of 60 degree thread forms that are straight and will give the 75% thread that most charts list(no pipe threads, acme or oddballs like Whitworth)
ND = Nominal outside Diameter
TPI = Threads Per Inch
TD = Tap Drill diameter
Simplified formula (you can do it in your head with some pitches)
TD = ND - (1/TPI)
Accurate formula (try it with known sizes-it works on all of them)
TD = ND - (.98/TPI)
For example, 1/4"-20 the tap drill is #7 (.201)
TD = 1/4 - (.98/20)
TD = .250 - .049
TD = .201
Simplified method works real easy with 16 threads per inch because you can just subtract 1/16" from the nominal diameter.
Ray,IN
02-25-2001 20:03:02
I prefer to use my pocket chart, because my memory isn't what it was. I can pull it out and select the drill I need from the same drawer. Sure helps this old retired toolmakers tired eyes too.
Brian G
02-26-2001 08:15:52
 Re: Re: tap drill sizes in reply to Ray,IN, 02-25-2001 20:03:02
Ray, I like your idea. Maybe I can carry it a step further. This is a good time of year for me to do this. I have the charts, so I can just sit down, "mike" up my drills to be sure I have the correct size for each tap and set up a tap/drill drawer. Then, when I want to tap a hole, the tap and the drill will be right there together. I'm sure I've got enuf extra drill bits, so I shouldn't have to use my tap drills for other purposes and vice/versa. It seems lately, the most obvious ideas have eluded me for years until someone else says something that jogs the cobwebs loose in the old gray matter. Thanks
Al English
02-25-2001 18:08:04
Hi Brian, That method starts you out with a hole that smaller than should be used, and with most taps, will result in a weaker thread. But that's better than guessing too big, since doing that can give you threads that won't hold at all...Al English
