Tool Talk Discussion Forum
Epoxy Question.
Jay87T
03-06-2006 10:11:35
Is there a way to rush the hardening process of epoxy, I love using it to mend things ie.plastic parts, but I hate waiting, would blowing cool or hot air advance the hardening time? or would it change the bond properties?
MarkB_MI
03-07-2006 18:11:04
 Re: Epoxy Question. in reply to Jay87T, 03-06-2006 10:11:35
There are two ways to accelerate the curing of epoxy: either increase the temperature or use a different epoxy.
Most epoxies are very temperature-sensitive and will cure quickly when warm. However, temperatures above 90 degrees F aren't a good idea because you'll tend to get bubbles in the epoxy. One easy trick to speed up the cure is simply to mix more epoxy than you need and let it set for a few minutes before you use it. The chemical reaction is exothermic, so your glue container will become hot very quickly. Once the epoxy warms up, you'll have to work very quickly.
Most epoxies come in "fast" (or "low temperature") and "slow" formulations. For example, Gougeon Brothers WEST epoxy is available with different hardeners depending on whether you need a fast or slow cure. They say there's no significant difference in the strength whether the fast or slow hardener is used.
Bus Driver
03-06-2006 15:45:04
As already mentioned, with epoxy, faster cure means weaker material.
mjbrown
03-06-2006 13:51:16
Epoxy will cure faster with some additional heat. Don't over do or you will weaken the strength of room temp cure epoxy. If you add heat when you are glueing wood, the wood will out gas and you will get bubbles in the glue. Faster curing epoxies( such as five minute) will not develope the same strength as longer cure formulas. Don't add more hardener!
Glen in TX
03-06-2006 12:53:26
Depends on what you're looking for in strength. They do make 1 and 5 minute epoxies. Temp and humidity will also affect curing time.
BigMarv1085
03-06-2006 11:06:44
In the aviation industry, we sometimes add more of the accelerator.Usually when you have a two part epoxy, the accelerator will be marked, just don't all the catalyst, but use all the accelerator.
