Tool Talk Discussion Forum
Taps and Dies questions??
John in Ct
03-06-2006 08:55:29
I need to get some Taps and Dies that I can't get from Snap-on ( bottom, etc.). I looked at a machine shop catalog and am now even more confused than before. On taps, what is the best brand and what features should I look for. I also saw taps that are .0005" or .001" larger etc, which size is good for mostly cleaning threads but sometime have to cut new threads? On Dies, I need to get some 6 point non-adjustable ones, which is the best? I have the adjustable dies and didn't know if I am cutting too much or not enough( kind of the same question I now have on taps) and have broken some too, so I figure the non-adjustable 6 point ( can fit a socket) were the way to go. Are any waranteed. Thanks!
Slowpoke
03-10-2006 00:41:05
 Re: Taps and Dies questions?? in reply to John in Ct, 03-06-2006 08:55:29
The oversized taps are used where the piece will be plated. The hole will have plating material on the threads that will bring them back to standard size. As stated below, use a T handle for the hex dies. You can't thread with a socket ratchet because the tap or die must be reversed about every 1/2 turn to break the chips. A ratchet will also break taps due to uneven torque. Good taps can be purchased in sets of three: starting, thu hole and bottoming for blind holes.
For cleaning holes and threads get a carbon rethreading set.
Fred Martin
03-09-2006 08:00:44
Just make sure the taps you buy have GH3 on them...that is the class of thread fit in all the sets. Hanson is another good American brand name. A few generations ago all the taps, dies and reamers were made from high carbon steel. As production increased...they came up with high speed steel cutting tools, harder and held their cutting edge at a higher cutting temperature...(read better)...Later came tungsten carbide and then ceramic cutting tools. Each one has it"s place. The carbon steels were okay...but...you had to go slower and less feeds. So, when you tap mild steel and some of the other softer materials, there isn"t that much heat at the cutting point, so they"re okay fot that. Now days with some of the more exotic alloys....it"s high speed all the way and maybe even cobalt tooling...harder yet. So, now you got an idea of what you need...go from there. Fred OH
Butch(OH)
03-06-2006 13:52:49
You haven"t even begun to be confused, LOL. The closer you come to understanding that taps and dies are consumables not durable goods the better understanding you will have on what to buy. Crap quality taps and dies are made both here and abroad but you stand a better chance with USA made. The HSS vs Carbon steel debate will go on forever but for general use I"d go with HSS. The lone advantage (and it"s a big one) for carbon is that a broken off tap can be shattered with a punch and the pieces picked out of the hole while same cannot be said for HSS. I keep a set of carbon steel taps around for iffy work just for that purpose, so they can be broken out if I break one. Rust from tread cleaning or trying to clean threads on hardened parts will kill the kean edge of any cutting tool and that includes your taps and dies, no matter who made them. Then when you try to tap new threads in tough materials with them you be asking here how to remove a broken tap. One set of taps and dies for junk work and one set for good work adorn my shop. When a good tap gets too dull for tapping new threads it goes in the junk work set and the one on the junk set goes in the trash. Its a cheaper route than trashing good taps and dies when junk work needs to be done, in my opinionated opinion.
Midwest redneck
03-06-2006 13:22:41
Get USA made taps and dies. The Steel is far better then the oriental junk. The US names are Morse, Clevland twist drill, Hertel, Niagra, APT, (alvord polk tool) Rock river tool. If the company selling the stuff is worth anything their catalog will list USA made and import.
MikeCatthemuseum
03-08-2006 19:33:30
 Re: Taps and Dies questions?? in reply to Midwest redneck, 03-06-2006 13:22:41
I totally agree with sir Redneck here. Buy good stuff. Yup, it's extremely expensive. It's also worth every penny. Cheap taps are a holy terror to work with. They dull quickly and break easily.
Glen in TX
03-06-2006 13:08:01
Plug type taps are what you find in most universal sets and work well for just cleaning threads. There are thread renewal sets available also for that. Taper taps are used for starting threads in harder materials. Can use taper tap, then plug tap, then bottoming tap last to finish the threads. Bottoming taps have full threads all the way across to finish threads on blind holes if needed. Taps are available in different H limit pitch sizes for thread clearance. Most sets will have standard H limit taps and many catalogs list the standard H limit sizes plus smaller or larger taps. Many special thread sizes and metric also are available from mscdirect.com or mcmaster.com and other vendors. Twist style taps are also available for chip removal problems.
Dave_Id
03-06-2006 13:27:34
 Re: Taps and Dies questions?? in reply to Glen in TX, 03-06-2006 13:08:01
May I add that twist type taps break very easlily, especially if you are power tapping. They work great for blind holes, as long as you don't jam the bottom of the hole. Everything Glen from Texas said is right on the money.
Greg_Ky
03-06-2006 12:06:51
Any Made in U.S.A. (not import) I use HSS they are about twice the price of carbon steel but out last them by five fold. Also not near as much breakage and stay sharper longer.
Stickler
03-07-2006 11:39:37
 Re: Taps and Dies questions?? in reply to Greg_Ky, 03-06-2006 12:06:51
I use rethreading taps & dies for cleaning/chasing existing threads. Rethreading ones are usually good enough even for bottoming, and they're soft enough to drill out if they break. My good taps & dies are only ever broken out for cutting new threads. Tip - if you must use a socket to turn one, use a t-handle on it, with the head in the middle, so it looks like a die stock or tap wrench. More taps are broken by uneven force than by torque. Also - use tapping/cutting oil even for chasing threads.
