Tool Talk Discussion Forum
3 wheel yamaha 225
ric1
03-05-2006 03:08:11
i have a 1985 yamaha 225 3 wheeler that i use around the farm runs good starts on the first pull everytime no matter how cold it is out its a 4 cycle single cylinder engine it blue smokes quite a bit but the oil level never seems to go down what else could make it smoke like this
doninoh
03-05-2006 08:05:05
 Re: 3 wheel yamaha 225 in reply to ric1, 03-05-2006 03:08:11
hey rick
check your oil and see if you can smell gas.
my old 225 smoked a little and level never seemed to go down. the needle and seat would let a little bit of gas go into the engine. my fuel shut off broke like most are on those old machines. just keep the oil changed and fix the shut off and use it.
have a good one don
ric1
03-06-2006 17:45:42
 Re: 3 wheel yamaha 225 in reply to doninoh, 03-05-2006 08:05:05
thanks don i will check the old girl out
dr.sportster
03-06-2006 18:08:32
 Re: 3 wheel yamaha 225 in reply to ric1, 03-06-2006 17:45:42
Trouble with these ATVs is with no odometer you forget to change the oil as often as you should.Speaking for myself anyway.
Stickler
03-07-2006 06:17:14
 Re: 3 wheel yamaha 225 in reply to dr.sportster, 03-06-2006 18:08:32
That is the truth for sure. And a lot of Hondas don't have oil filters, just a centrifugal trap. Hardly anyone ever bothers to clean that, since it involves removing a side cover and an expensive gasket. I've seen them so full of sludge the clutches wouldn't work anymore.
