Tool Talk Discussion Forum
pressure washer hose and fittings
clueless
03-04-2006 06:50:01
Guys. I am clueless about pressure washers. Hopefully you can help me out. Most of the residential grade ones (2000-2500 psi) I see use 1/4 inch hoses. I am thinking about buying a 20 foot telescoping extention wand to allow me to wash the vinyl siding on my two story house. The extensions all seem to have 3/4 inch hoses.
Will this cause any problems? Are the fittings the same?? If not are there adapters available??
Thanks in advance.
baler 46
03-04-2006 09:15:43
 Re: pressure washer hose and fittings in reply to clueless, 03-04-2006 06:50:01
Hi
3/8 inch hose will be ok you need to have the right size nozzle on the end of your wand or it will not work right.That little hose size will not know the difference.
clueless
03-04-2006 06:53:13
that was 3/8 inch hose on the extension wand. Not 3/4 inch. I noticed my mistake after I had already submited the question.
