Tool Talk Discussion Forum
Got my 20 holes done Thanks
cooker .308
03-04-2006 06:24:29
Thanks for the help, used alittle advice from everyone. What worked for me was. 1300 speed, peck drilling, lots of 'Ready Tap'cutting fluid,verry easy on the feed and changed the bit after 10 holes. No broke bits and holes look real good. I was drilling the block to act as flaws as I am studing utlrasonics, I have access to a ut/ machine but no blocks. Thanks again Cooker.
Davis In SC
03-04-2006 18:49:40
 Re: Got my 20 holes done Thanks in reply to cooker .308, 03-04-2006 06:24:29
Glad to hear that !!! Being able to make do with less-than-optimum tools or machines is what being a true machinist/mechanic, etc is all about... Just have to use some ingenuity... The folks here always seem to have lots of good ideas, to help others out...
TimV
03-04-2006 06:46:27
Cooker: Glad to hear it! Sometimes you"ve got to do the best you can with what you"ve got to work with--glad it worked out for you.
NEsota
03-04-2006 06:30:33
The advice you received and success you had will help me with a project I have. Thanks for the posts.
