Tool Talk Discussion Forum
shop lighting
jack-iowa
03-01-2006 19:35:15
Going to replace the incandescents in the shop. Thinking zero degree start flourescants.
Are they good or is there something better?
thanks
Kevin Bismark
03-03-2006 18:34:32
 Re: shop lighting in reply to jack-iowa, 03-01-2006 19:35:15
I agree, we have 12 8 foot 4 lamp t-8 fixtures in our shop and 3 more above the work benches and they are great cheep to run and lots of light, have them wired up so I can run the front half or the back half, both halves are on most of the time anyway, brighter in there than I thought it would be.
Jack-Iowa
03-02-2006 06:28:00
Thanks
David - OR
03-02-2006 05:30:10
Use fixtures containing T8 tubes with an electronic ballast. Most will strike down to 0 degrees (F). The electronic ballast is energy efficient and does not have an obnoxious 60 HZ hum.
About the cheapest route is the Lithonia or Metalux 8 foot tandem channels. These come with one electronic ballast and take 4 F32T8 tubes. Figure about 11000 lumens per fixtures. About $35 at big box stores or electrical wholesalers.
If you look in most grocery stores, you will see long rows of these fixtures mounted end-to-end. This provides nice even lighting and saves work in routing the wiring, since you can run it inside the row of fixtures.
As an alternative, you can 17000 lumens per fixture with the "Heavy Duty Commercial Striplights". These take 2 F96T12HO tubes, strike down to -20 degrees, and use a magnetic ballast. These run about $50 per fixture. The two downsides of these is that they are less energy efficient and have a fairly noticeable 60 Hz hum.
MarkB_MI
03-02-2006 19:04:59
 Re: shop lighting in reply to David - OR, 03-02-2006 05:30:10
David,
I second your recommendation to use 8' 4 tube T8 fixtures. I used the Lithonia fixtures sold at Home Depot in my shop and they work very well. I have six fixtures in my 30x40' shop and they are more than enough.
Although these fixtures are good down to 0 degrees F, the electrical inspector insisted that I add at least one incandescent or halogen fixture. I tried to explain to him that I didn't intend to be in the shop if it got below zero, but it was easier just to add another light.
RickL
03-02-2006 02:20:53
thats all I run but use the commercial grade have twenty some in the shop. But when one bulb does go bad it make the whole light not work. No biggy just so you know ahead of time. I thought had fixture problem. I in Iowa also come look if that would help,I am loceated in southeast part
