Fouled plugs
Phil
11-30-1998 17:42:46
I have a Ford model 860 that fouls the #3 & #4
sparkplugs continuously. They are not fouled with
oil, but with dry carbon black powder. The tractor
uses very little oil. You can remove and clean the
plug but it still will not fire. The only thing that seems to work is to replace it with a new
plug. Does anyone have a reason or a solution for
this problem?
sign man
11-30-1998 18:25:12
 Re: fouled plugs in reply to Phil, 11-30-1998 17:42:46
: I have a Ford model 860 that fouls the #3 & #4
: sparkplugs continuously. They are not fouled with
: oil, but with dry carbon black powder. The tractor
: uses very little oil. You can remove and clean the
: plug but it still will not fire. The only thing : that seems to work is to replace it with a new
: plug. Does anyone have a reason or a solution for
: this problem?
Granted sparkplugs aren't as good as they once were with the type of fuel we have.
so problem may be coincidental. My bet would be that you are cross firing through poor plug wires or a cracked distributor cap. Run the tractor in a pitch dark area check to see if you can see the wires jumping spark. Also, remove your cap and check for carbon tracks.
