Tool Talk Discussion Forum
Shop Door
Joe MD
02-28-2006 08:37:30
I'm getting farther along building my woodworking shop in our old dairy barn.
Now I need a door, but am unsure if a garage door will work. The barn currently has slider type doors on the outside that must be 60 years old. My plan was to install a garage door inside of the slider so you could close the slider and not see the ugly garage door.
Problem is my opening is only 8' wide by 8.5' high and the interior ceiling height is only about 9'.
Will a manual garage door even work? I have no experience with them. Other ideas? I would like it to be somewhat insulated so I do not want to use a roll up door.
MarkB_MI
03-02-2006 18:39:58
 Re: Shop Door in reply to Joe MD, 02-28-2006 08:37:30
You can order an overhead door in pretty much any width, so that's not an issue. I suspect that 8'6" is a standard height, but you'll need to check with the manufacturer. Certainly 8'0" high is standard.
Most overhead doors require 12 inches of overhead clearance for the tracks, plus extra for a power opener. However, manufacturers offer "low overhead" kits; check with the manufacturer to see how much clearance their low overhead kit requires.
vrickster
02-28-2006 16:22:33
third party image
I have a similar problem with a 16' wide by 12' high opening in my shop. I do not want to loose any headroom and a slider is so heavy/hard to push. I am going to do a "4 fold" door like many firehouses have.
Joe MD
03-01-2006 06:56:17
 Re: Shop Door in reply to vrickster, 02-28-2006 16:22:33
That door would be perfect for my situation.
Any clue where I get one? I wonder if the overhead door company whose vans I see everywhere sells them.
Thanks for the picture.
vrickster
03-01-2006 14:45:05
 Re: Shop Door in reply to Joe MD, 03-01-2006 06:56:17
These doors would cost you a mint to purchase. Check this link out for a do it yourself or hire someone to do it. I am using this concept but modified to use metal instead of wood. This concept has them opening in the out direction, as I will do living in S Texas where there is no snow. You could modify to open inwards if snow is a problem.
Don L C
02-28-2006 09:54:34
Joe --- You don't have a problem...the door you will need comes for 8'x8' opening....call out the company you want to buy the door from.....I use "OVERHEAD DOOR" they made the first overhead doors(steel)...they can tell you how high to frame the opening.....mine is 8'.....
That will give you room to insulate....get the insulated steel door its much stronger..... you can get it with or with out windows....they put it up in less than 2 hours..... ...
Their installed price was less than the lumber co. and I had to install it.....
goood luck Don SW Ohio
