Tool Talk Discussion Forum
Milwaukee Drill ID
fencline
02-27-2006 16:13:28
I just aquired a Milwaukee Magnetic drill. The magnetic base is Cat # 4221 and I can find that on the Milwaukee website. (Parts breakdown)The tag is missing on the drill and I am having a problem getting a Parts breakdown. Does anyone know which drill units were used with these bases or how I might find that out. I have dial up and browsing is VERY slow. I also could not locate the Operators manual for the base on the website (Hoping it would indicate the optional drills )Any Ideas? Thanks,
Andy
Fred Martin
03-02-2006 11:55:56
 Re: Milwaukee Drill ID in reply to fencline, 02-27-2006 16:13:28
I bought a used magnetic drill stand with an air operated drill on it...I took the air drill off and found that if I made up a piece with the correct pipe threads on it (forget size) and the other end to slide in the tee slot type opening...I could just mount a heavy half on it. Worked fine for years. Fred OH
van robinson
03-01-2006 20:05:06
The magnetic base you asked about used one of these motors.
4253-1
4262-1
4265-1
4292-1
4297-1
Van Robinson
Milwaukee Electric Tool Corp.
Dave NE IA
02-27-2006 18:42:19
Call the Company, they will be pretty helpful usualy. Local distributors in our area are having a rough time with them, and are droping their line. Be sure to check with different places for prices as they vary a whole bunch. The Co. will send parts right to you and may be your cheapest option, again check it out. They may question the no tag ordeal, so be prepared for that, I have quite a few that the tags are banged up so bad you can't read them. Dave NE IA
