Tool Talk Discussion Forum
Flux core welding wire
BobOHIO
02-26-2006 08:18:27
Hi- I was looking at the Lincold HD 3200 wire feed welders at Home Depot. I make some projects usually mild steel. Will the flux core wire draw dampness if not used like a welding rod? I don't have heat in my garage. Currently store my rods in a sealed plastic container with no problems but I wouldn't want to take a spool of wire on and off every time. Also, can you weld aluminum without the shielding gas? (flux cored aluminum wire? if there is such a thing) Thanks
BobOHIO
02-27-2006 16:36:59
 Re: Flux core welding wire in reply to BobOHIO, 02-26-2006 08:18:27
Thank you everyone for your help. I appreciate your suggestions. Bob
retired farmer
02-26-2006 18:18:45
My experience, forget the Lincoln and get a Miller 130. You won't be sorry. I got one for around $600 and couldn't be happier. Supposed to weld to three sixteens but will do one quarter without any problem. Mine stays out in the shop all the time and haven't had any problem with the wire. If I had use for it I would have a Miller 250. They are an excellent machine.
OK-AL
02-26-2006 16:36:29
Flux core or mig welding wire will rust. It's best to store the wire in a heated room when not in use. The worst part is that rusty wire will destroy the inner liner of the mig gun, so you'll end up replacing both the liner and the spool of wire.
If you're wanting to weld thin metal, say 1/8" or thinner, then mig is the way to go. Otherwise, a good stick machine may be your best bet.
Also, you do have to use sheilding gas when welding aluminum, regardless of the process, i.e. tig or mig.
OK-AL
John Niolon
02-26-2006 16:13:15
Bob,
up to a point you can do anything with wire you can do with stick... if you buy enough amperage.
but on the other end of the scale... with light guage material... wire is the only way to go.. I use wire almost exclusively from 14 guage up to 3/8 material. Gas shielded leaves the weld area virtually clean... flux core is really meant for times when you are working outside and the wind would blow away your shielding gas. BUT flux core is not as clean welding as gas shield... lots of splatter to clean up after.
I agree with the auto dark helmet.. it's made me a much better welder... with wire OR stick. I've got a 100 amp Hobart 'suitcase' 110volt welder for very light guage (.023 wire), a Millermatic 200 for heavier stuff (.035-.045 wire) and an old Lincoln 225 ac/dc tombstone for stick... but it hasn't even been plugged in in years. a little practice with wire will make a believer of you.. much easier to start without sticking (for me anyway) and produces just as stong welds.
We welded a double set of discs that had the back section torched off... it was 2x4 rectangular tubing... we just cleaned up the area to be welded with a grinder and clamped it back together. one pass around than added 3/16" thick 4" bar stock patch plates on inside and outside with full weld around it... drug it around all day and it's still holding... one more thing.... wire welding wants a much cleaner weld area than stick... it's much less forgiving on weld prep.
later
john
Bill in Colo
02-26-2006 09:19:02
I doubt if you will have moisture problems,I have not,may go two to three months without use. I have a Hobart wire feed and I have gas shielding,but seldom use it, mostly use flux core. I have a century ac stick and a lincoln 200 pipeliner too. The place I really like flux core is on galvanized metal, it works better than anything else I've tried.
In the shop where my son works they do alot of repair work using flux core with gas shielding.
benny2
02-26-2006 08:38:09
 maintenance headache Re: Flux core welding wire in reply to BobOHIO, 02-26-2006 08:18:27
Why bother with Fluxcore if you have a good stick machine. You find the Flux core much more of a maintenance headache?
BobOHIO
02-26-2006 08:49:19
 Re: maintenance headache Re: Flux core welding wir in reply to benny2, 02-26-2006 08:38:09
Hi Benny- I don't have experience with a wire feed machine. I have a Miller stick machine. Was hoping to use wire feed on thin metals. It looks easier to start and stop than my stick welder. Easier set up and tack also.
benny2
02-26-2006 09:06:22
 Re: maintenance headache Re: Flux core welding wir in reply to BobOHIO, 02-26-2006 08:49:19
Go out and get yourself a good "Flash Darken Helment" it will be like a new welding world! there is little diference in the welding experence between using "flux core" wire feed and "Flux Coated" stick rod as far as welding quality is concerned and the cost of welding is going to COST much more with wire.
Bob
02-26-2006 08:54:04
IMHO, if you're going to "spring" for a wire welder, spend the extra money and get a gas-shielded unit.
