Tool Talk Discussion Forum
PTO powered log splitter
Kippster
02-26-2006 07:30:52
I"ve been looking for a PTO powered log splitter for my Farmall H. I"ve seen some that were like a big cone wiht threads on it. Can someone give me some hints on where to find one of these kritters?? I want this rig to be as simple and as inexpensive as possible, so the threaded cone idea sounds good. Thanks for any input. Kippster
Kippster
02-28-2006 07:20:27
 Re: PTO powered log splitter in reply to Kippster, 02-26-2006 07:30:52
I guess in most people"s eyes machinery is at fault for the majority of injuries. Machinery is only as dangerous as it"s operator as far as I am concerned. If you try to unplug a corn picker when it is still running, you are asking to lose an arm. If you run a JD model m on a hilside, you"re looking for a rollover. Thanks for the input anyway. Everyone is entitled to their oppinion and I don"t blame anyone here for voicing it.
Kippster
02-28-2006 07:20:20
igloo
02-27-2006 17:49:01
I have the one that goes on the axle when you take off the wheel. It's called the "stickler" I bought mine two years ago and I love it. If you pay attention to what your doing, and block up the vehicle correctly you will have no trouble. I have not found a piece of wood I couldn't split. I am going to rig mine up with an old rear end to mount to the back of my tractor and run off of pto.
igloo.
R Fink
02-26-2006 11:07:23
I have one of those splitters and they are very dangerious not worth useing.
Dave NE IA
02-26-2006 09:55:20
I know where there are a couple of them, both are in sheds and hardly used. However neither farmer will sell them. They will indeed kill you. I have a screw that goes on the pto, I could give you, but I also seen what can happen, thus will decline. It has no monitary value, and I had big ideas at one time.
My brother up in MN. had a friend that purchased the hub mount for his pickup. He jacked it up, but did not chain his pickup to a tree and stuck a chunk on that did not split and the truck took off down the field. (with the chunk on the wheel like a game leg) He said it was quite a site to see. He felt very good that his small son had just insisted on getting out a little before the event, as it ended up in the ditch. I'm certianly sympathetic towards not wanting to spend alot, but they are trouble waiting to happen. Dave NE IA
benny2
02-26-2006 08:46:35
 Split Wood or DYE Re: PTO powered log splitter in reply to Kippster, 02-26-2006 07:30:52
What you want to DYE early?? Screws were NEVER made to go on the PTO it just turns to fast. They used to have them to bolt on a car or pickup rear drive wheel. I think all the makers of these have been KILLED with lawsuits!!
paul
02-26-2006 18:34:30
 Re: Split Wood or DYE Re: PTO powered log splitter in reply to benny2, 02-26-2006 08:46:35
He posted in several forums I guess, I repied to his other one so I won't repeat myself much, but Unicorn still makes the wheel one, they are online. There were several brands of pto ones made, you run the tractor at about idle, spins at a couple 100 rpm if that.
This is discussed about every 3 months here, a search will bring up info here.
--->Paul
