Tool Talk Discussion Forum
Breakaway Trailer brakes
Ryan - WI
02-25-2006 18:52:18
I am planning on installing a breakaway controller on my trailer this spring (I don't use it in the winter) and I had a thought. The trailer already has a full size auto battery in the toolbox which is used to power the winch and is charged via a + lead from the truck. Can I just put in the switch to activate the brakes in a breakaway using the existing battery or should I just by the whole shebang and have two batteries in the toolbox? I am trying to save some room but if needed can go with the commercially available set up.
tn terry t
02-25-2006 19:13:41
 Re: Breakaway Trailer brakes in reply to Ryan - WI, 02-25-2006 18:52:18
KCTractors is right on the money no need for extra battery
KEB
02-25-2006 19:10:25
That's exactly how the vast majority of travel trailers work. The same battery that's used to run the trailer interior is used with a break-away switch for emergency brake operation.
Also how my 5th wheel flatbed is wired.
Keith
KCTractors
02-25-2006 19:06:37
Any 12 volt source will work as long as it will hold 12 volts for, I believe 15 minutes, and the source has to stay with the trailer if it breaks away.
Cliff Neubauer
02-25-2006 18:59:59
A few weeks ago I put a break away system on our gooseneck livestock trailer and I just went to TSC and got the $45 model they sell. It has a battery with a built in charger and LED lights to indicate how much charge the battery has.
