Kinky cables
SLAG
02-23-2001 22:00:31
Will an old electrode holder with a weak spring cause the pos. cable to kink? the rod holder gets warm sometimes but hate to replace it, we been threw a lot together, sentemental I guess. [spell that cheap!]
T_Bone
02-25-2001 07:10:07
 Re: Kinky cables in reply to SLAG, 02-23-2001 22:00:31
Hi Slag, Try taking apart the handle to make sure the cable to connector is tight. Heat in either clamp is from resistance, bad connection. The rod should bend easy with out poping out of the electrode holder if the spring is good. If it needs replaced, Tweeco makes the best clamps and twist connectors.
T_Bone
Jim K
02-24-2001 06:28:05
Slag the answer is no. what you need is new cables, what is most likely is that the insulation has deteriorated and most likely the copper is also, If you don't want to part with the old holder try to get the spring replaced or tightened, but do get new cables the same size or larger.good luck
Jim K
slag
02-24-2001 17:36:45
 Re: Re: Kinky cables in reply to Jim K, 02-24-2001 06:28:05
But their almost new, well maybe a year old.
Jim K
02-25-2001 05:44:54
 Re: Re: Re: Kinky cables in reply to slag, 02-24-2001 17:36:45
Is it actually welding cable or just a large copper wire? Go to a welding supply house and get cable made for welders. It should'nt give you the problem you describe, unless your constantly running them over with a bulldozer.Good luck
Jim K
