Tool Talk Discussion Forum
vertical hydraulic pump?
HiTech Redneck
02-24-2006 15:31:54
Can a hydraulic pump be mounted vertically as well horizontally? Thanks for any assistance you can provide!!
HiTech Redneck
02-25-2006 09:41:56
 Re: vertical hydraulic pump? in reply to HiTech Redneck, 02-24-2006 15:31:54
The application I was thinking about is similar to the B&S vertical engine with a 2 stage pump.Thanks to everyone for the quick replies!!!
Midwest redneck
02-25-2006 04:37:19
Vern from MI. is right as long as it is not a piston pump with a case drain then you are okay. A flooded inlet is very good too. See ya.
Vern-MI
02-24-2006 18:09:57
Piston pumps have a case drain that is situated on top so they are position sensitive. The piston shoes must be lubricated where they slide on the swash plate so the case must be filled with oil. Gear and vane pumps can be mounted in any direction.
Ryan - WI
02-24-2006 17:02:59
The pump in my father in law's skidloader says yes.
Maark
02-24-2006 16:35:26
I think they will only pump when laid down on a certain side.
Charles (in GA)
02-24-2006 15:55:35
Why not?
I doubt the pump would care.
Charles
Buckeye Bill
02-24-2006 18:18:34
 Re: vertical hydraulic pump? in reply to Charles (in GA), 02-24-2006 15:55:35
Sure will.
We used to manufacture a power unit mounted vertically in a bucket like container powered either by a electric motor or a vertical shaft B&S engine. We used a 2 stage Barnes hydraulic pump similar to what a wood splitter uses.
