Tool Talk Discussion Forum
air quick couplers
paul
02-23-2006 14:37:27
Looking to set up a small air tool setup in my shop. Sometimes small setups grow bigger, so might as well start out right....
Is there any difference on the quick couplers? My current old tank & compressor seems to have 'type T, automotive' connectors.
The local farm store carries the least of these, looks like more 'type M, industrial' ends, as well as 'type A, ARO' connectors.
Any reason not to keep going with 'type T', any one better or worse than the other?
As always, 3 standards. And yea, looks like there are female universal couplers, that work out ok?
--->Paul
shannon from ohio
02-25-2006 20:22:29
 Re: air quick couplers in reply to paul, 02-23-2006 14:37:27
Go with MILTON-- Stay with MILTON-- No problems again..... .
T_Bone
02-25-2006 07:57:06
Hi Paul,
The best thing I ever did was hit Wally World and bought 50 male and 25male conntectors made by Ingersol Rand. I have no idea who makes them for IR. The seam to be a quality connector tho as no leaks in 10yrs.
I then threw out all my odd ball connectors as this quanity should last me a life time.
T_Bone
paul
02-25-2006 08:08:16
 Re: air quick couplers in reply to T_Bone, 02-25-2006 07:57:06
Thanks guys. I found a Pioneer brand 'universal' female connector to get me started, they make good hyd stuff, seems like a good start until I pick a design & go with it. :)
--->Paul
Richard Scott
02-24-2006 17:45:06
I also tried the brass Harbor Freight couplers. Leak like a sieve.
Their silver ones are a major brand (AmFlow), & don't leak, the brass ones are made in China, which is why they leak, of course.
Most folks around here use the industrial style. They seem to disconnect more easily under pressure.
Bob
02-23-2006 22:00:08
"T" means "TRUEFLATE", the manufacturer who originally made that style.
For one reason, or another, all my air fittings are "T" style, and I see no reason to change them, as they work well for me.
That's not to say there's anything wrong with any of the other styles, either, but why fix it, if it ain't broke?
jeffcat
02-23-2006 17:21:29
You should try it when you want to run something up at the farm! All of my Dad"s stuff is from 1950 or so. He just swaps the couplers around when he needs to hook up an "odd" unit. All of my stuff is that tripple type of unit. Just one neighbor down here has the shop type of couplers. If you have a harbor freight near by they sell couplers in bulk. They have two types and are silver. I bought about twenty pairs and now EVERYTHING matches! Ha ha. Jeffcat
bjr
02-24-2006 06:59:46
 Re: air quick couplers in reply to jeffcat, 02-23-2006 17:21:29
Just stay away from the brass packaged couplers at HF I bought them 'cause they're cheaper, well the very first time I tried to plug in the female coupler blew apart big time, parts flew across the shop. The female counter person just made fun of me when I tried for a exchange and then ignored me. The silver steel couplers seem be alright though. bjr
Charles (in GA)
02-23-2006 14:57:20
If you don't have but a couple now, trash everything and start over with the "industrial interchange" type male nipples. These are the most readily available and common type, the automotive and the aro type are second most common types.
Several different types of universal female couplers are made. Home Depot has one, Aro/Camel makes one that takes all three types of nipples.
Charles
At the Library
02-23-2006 14:50:38
Get the univeral female type. Actually, I think they only work with the industrial and automotive fittings. The are about $6 each but worth it. It's too much trouble changing fittings if you get another tool that doesn't match your setup.
Slowpoke
