Tool Talk Discussion Forum
Small tubing bender
Erik in WI
02-22-2006 08:41:07
Does anyone know were I could get a tubing bender small enough to bend 1/8" to 3/16" aluminum tubing? The one I have only goes down to 1/4", and just kinks the small stuff.
Any thoughts?
Thanks Erik in WI
RayP(MI)
02-22-2006 17:51:52
 Re: Small tubing bender in reply to Erik in WI, 02-22-2006 08:41:07
Check with your local auto parts vendor. They have benders for brake lines, etc.
Jerry L /AZ
02-22-2006 14:32:59
try filling it with water and freezing make the bends and tet it thaw. works great, hope thet helps Jer
steve from mo - dangit!
02-22-2006 08:55:47
 How precise? in reply to Erik in WI, 02-22-2006 08:41:07
One bolt, two fender washers, and a short stack of smaller washers would allow you to make a tubing bender for almost any size tubing. The kinks happen when the tubing flattens; so all you need to do is stop the flattening.
Alternatively, could you use a different type of tubing, like copper or PVC?
Erik in WI
02-22-2006 09:01:06
 Re: How precise? in reply to steve from mo - dangit!, 02-22-2006 08:55:47
Steve, I just got off the phone with the local parts house, and they have one that goes down to 3/16" They also said to bend smaller stuff, fill the tube with sand and plug the ends before bending. So I think I will give that a try. Also it is for show, so nothing else looks as good as polished alum. Thanks Erik in WI
