Tool Talk Discussion Forum
Wood splitter idea's
FarmerSid
02-22-2006 06:27:52
Hey All! Need some idea's from you smart folk. Need to get a wood splitter. Been searching here and the rest of the net for idea's on building a wood splitter but can't find anything. Would like to build one that splits in both directions. I have access to all kinds of steel in various shapes and sizes. Got a few 4" X 24" hydraulic cylinders to use on it.
Would anybody have any plans or pictures that I could go by?
Everybody's help is greatly appreciated.
Cheers!
Sid
Dan in Ore
02-24-2006 05:03:58
 Re: Wood splitter idea's in reply to FarmerSid, 02-22-2006 06:27:52
I built one 25 years ago. Am still using it. Put it on a moble home axle that I shortened. Welded the shortened axle right to the bottom of the I-beam. Have an 8 HP Briggs and Stratton coupled to a 2-stage pump. The push plate is on the ram.
Important point is to be sure and get a single detent valve (detent in the reverse position only). That way you will be able to pick up another piece while the ram is returning. You don't want the detent going in the forward direction, because you want your hand on the valve handle in case something goes wrong (like a helpers hand getting in the way).
Mount the engine on rubber or spring mounts. This keeps the vibration to a minimum. Also mount the pump directly to the engine.
I got a lot of my parts from Northern Hydraulics. They used to be very reasonable, not sure how they are now. It was all quality material.
If you have any more questions, e-mail me at [email protected].
Good luck
Dan
Dave NE IA
02-22-2006 22:00:46
Tim, is on the right track, I pesonaly prefer the wedge on the far end, but my wood comes off the splitter and goes down into the basment. I have helped some friends split wood with their tip up models, and would not have one if I had to use it. I usualy go for the bigger diameter logs that are to heavy to lift. The tip up splitters when tipped up make it real extreem work out of positioning the log. When they are in the horizonal position the wheels get in the way for comfort while working. I have made a lift table --it is 3/16 plate steel hinged to the I beam that when layed towards the ground is at about a 45 degree angle with the lower end having a slight bend upwards. We can roll the big ones up over the 3in upward bend on the steel plate lift table. By hitting a lever it is lifted to the horizonal position with a small cylinder. The table extends a little beyond the wedge so you can swing the chunk to be resplit with one hand, no lifting. The other half that has to be resplit is being held by the I beam. Again no lifting. Another reason I prefer the wedge on the end of the I beam is if I do split in the timber I can pile the wood off the end as the splitter pushes the pile a way or the splitter backwards without anyone manualy doing anything. If I split smaller chunks the table stays flat or level so your help can have three or four pices on deck waiting for the split. I usualy load the big chunks into a trailer with a loader so I can min. my limited time in the timber and split in evenings at home as time allows. The tilt pan is only lowered to just below the trailer floor just behind the trailer so the kids can roll the big ones onto the lift pan, again no one has to work hard. I stoped to help a friend a couple weeks ago split some wood with his new $1,400.00 tip up splitter, he was splitting 20inch diameter pretty straight grain wood. We shut it off except for the knotty ones as it was less work with a maul, and 5-8 times faster. I have four other guys with the tip ups that borrow mine with the lift pan as their backs like it better even if their wives get bent on having a splitter and then borrowing one. We will be mounting lift pans when I get the time to do it for them. I feel if you are unloading from a pickup height then on a horizonal splitter it probably would not be all that bad as you would not have to lift them from ground level. Dave NE IA
Tim B From MA
02-22-2006 09:17:20
Sid
Many years ago I bought a "Mighty Murc", made by Tilton in N.H. For the most part, it is very smartly and efficiently made. I will try to post a picture for you, but won't be able to till the weekend.
In the meanwhile some suggestions:
Firstly and most important - put the wedge on the piston and the stop at the end of the splitter. Not sure if you can do a 4 way wedge this way but my opinion is you would not need to. It is very easy to make a split, back-out the wedge, rotate the log on the "table" split again, and again, and again. No need to pick up the wood since it won't be pushed onto the ground everytime.
Use a square tube (e.g., 4 X 6) as the axle support, and use it as the hydraulic reservoir.
Make the "table" a comfortable height so you can hold the log against your thigh with one hand while the other hand is busy at the valve control.
Put an actual table opposite the side you stand on to catch the half of the larger logs opposite you after you make an initial split.
Use a two-stage hydraulic pump.
Use a control valve that will stay engaged for backing up the wedge while you pick up the next log.
With the right king of valve set-up you can put a movable, lockable ring on the piston that will trip the control valve as it goes back - used when you are splitting consistently sized short logs so time is not wasted with un-needed piston travel. I'll try to get you a picture.
Regards,
Tim
Rickstir
02-22-2006 07:35:46
Here's 3 point hitch splitter. This site also has plans for gas powered. I used their workbench plans and was pleased.
FarmerSid
02-22-2006 08:13:49
 Re: Wood splitter idea's in reply to Rickstir, 02-22-2006 07:35:46
Thanks Rickstir! I've been to that site already. I should have stated that it has to be gas powered as my tractor is not at my house. Just looking for some pictures of one that someone has and some design idea's from it.
Cheers!
Sid
GaryK
02-22-2006 18:21:54
 Re: Wood splitter idea's in reply to FarmerSid, 02-22-2006 08:13:49
I just looked at the site that Rickstir mentioned. the home page has links to a bunch of plans. There are plans for a self contained hydraulic wood splitter under the tractor equipment heading. The site is how-to-plans.com.
Rickstir - know of any ther sites like this?
