Tool Talk Discussion Forum
Any body know any thing about?? Part 2
old
02-21-2006 12:29:49
Well been playing with the little genny set and have it up and running now. Has 4 outlets that have around 130 volts ac on them. The little thing purrs like a kitten. Now I just need to figure out what in the world to do with it.
Rauville
02-21-2006 16:21:28
 Re: Any body know any thing about?? Part 2 in reply to old, 02-21-2006 12:29:49
Bet you paid less than what I had to for a little 2KW Honda that my Wife wanted for her travel trailer.
(Can you believe over a grand!....ouch!)
Tim B from MA
02-21-2006 19:19:21
 Re: Any body know any thing about?? Part 2 in reply to Rauville, 02-21-2006 16:21:28
I'm guessing you bought the Honda EU - I have the 3kw version for camping. They are so quiet it is worth the extra dough for that purpose.
I have heard people using "regular" generators at state parks - very loud and obnoxious. With mine, if I can keep it a couple hundred feet from the neighbors, they can barely here it.
1EYEDWILLIE1
02-21-2006 16:13:30
I've always maintained the best way to prevent your power from going out is to by a generator.had mine for 14 years,has 12 hours on it.and a lot of that is from its once a year test run.best thing i did was convert it to run on natural gas,dont have to worry about the gasoline going bad.Bill M.
Frank (N.Mi.)
02-21-2006 17:09:27
 Re: Any body know any thing about?? Part 2 in reply to 1EYEDWILLIE1, 02-21-2006 16:13:30
So how did you do that exactly? I think I would like to do that with mine. (convert to lp or propane that is).
1EYEDWILLIE1
02-22-2006 16:52:08
 Re: Any body know any thing about?? Part 2 in reply to Frank (N.Mi.), 02-21-2006 17:09:27
Link
Glen in TX
02-23-2006 11:57:05
 Re: Any body know any thing about?? Part 2 in reply to 1EYEDWILLIE1, 02-22-2006 16:52:08
www.impco.ws/
www.rwsupply.com/
DickTN
02-21-2006 15:53:25
Old, you may have the genny running too fast. Seems like you should have closer to 120 than 130. 'Course, you may not have had it loaded, which should drop the voltage some. There's a pretty inexpensive gadget called a Kill-A-Watt meter which will give you a reading of voltage, frequency and other stuff. Ususally can find them on E-Bay. Worth having to check your genny.
kidbob
02-22-2006 07:44:15
 Re: Any body know any thing about?? Part 2 in reply to DickTN, 02-21-2006 15:53:25
The speed does not change the voltage, that is a voltage control which may be adjustable. The speed only controls the frequency, you want 60. If you can't find a frequency meter just set it at the rated RPM, or plug in an electric clock, let it run a while and compare it to one pluged into the power company.
Greg_Ky
02-21-2006 12:39:01
Pray for a power outage. Since I have Purchased a generator several years ago the power has only been off long enough to use it twice. I still get her out a couple of times a year for a little exercise. (Change oil & Filter and change the gas).
