Tool Talk Discussion Forum
Any body know any thing about??
old
02-20-2006 16:56:12
Koler 4 cylinder engines. I picked up a motor/genny set up today and it has a 4 cylinder Koler flat head engine and I need to pick some brains as to what I really have and maybe how old it might be.
Thanks
xragman
02-21-2006 06:53:59
 Re: Any body know any thing about?? in reply to old, 02-20-2006 16:56:12
OLD have you tyied www.kohlerengens.com
jdemaris
02-20-2006 18:46:32
The older Onan and Koehler generators put out full sine-wave power just like the power company does. Many if not most of the newer generators do not and only put out a peak of 150 VAC instead of the normal 170 VAC (120 volts AC house current peaks at 170 VAC on the top of the sine-wave). Smokstak.com has a great forum specifically for older Koehler generators. It's at: Link
old
02-20-2006 19:14:00
 Re: Any body know any thing about?? in reply to jdemaris, 02-20-2006 18:46:32
Tried to go there but didn't see how to sign up to be able to post a message. HELP
jdemaris
02-20-2006 19:47:59
 Re: Any body know any thing about?? in reply to old, 02-20-2006 19:14:00
You can register for free and be able to post. If you've customized some of your settings with your web-browser though, you might have trouble. The "allow cookies" function has to be working, and by default, it usually is unless you intentionally disabled it.
To register at smokstak, go to:
http://www.smokstak.com/faq_smok.htm#subscriber
RWK in WI
02-20-2006 17:12:32
We had a Kohler 4 cylinder engine / generator at a cottage we bought in 1957 - it wasn't new then but it worked well. It was water cooled and ran at 1200 RPM and would start when a light was turned on. I believe it was 12 volt starting as we could jump it from the "new" car when the battery was down. It had a hand crank but the way it was set in the shed we couldn't get at the crank. I believe it put out 1000 or 1500 watts. The automatic control for starting was mounted above the generator end in front of the radiator. I remember that when one spark plug fouled the lights would really flicker. In the mid to late 60's we upgraded to a larger generator with a single cylinder Kohler engine at 1800 RPM. We got power lines in 68.
I might have a manual from the old generator if it would help you.
old
02-20-2006 17:42:30
 Re: Any body know any thing about?? in reply to RWK in WI, 02-20-2006 17:12:32
The manual might help this one is a 6.5KW set up. I just got it today and need to work on it a little to see if I can get it to run.
lucasss
02-20-2006 18:59:34
 Re: Any body know any thing about?? in reply to old, 02-20-2006 17:42:30
those engines were also used up to present in those trailers that phone co uses. it runs air compressor,blower for fresh air and electricity.2-5/8 bore size. lucas
