Tool Talk Discussion Forum
Diesel leak from injector pump, Help?
Johnny Mac
02-18-2006 13:31:06
Goodaye to anyone reading this,
The old girls problem (Massey 35)is after a heavy days slashing, she developed a pretty constant leak from the diesel cut off, in the injector pump.
My question is there a quick fix or do I have to replace the injector pump? (and if so how involed is the job of replacing the pump?)
Any help or guidance would be greatly appreciated.
Cheers,
Johnny
TomTX
02-19-2006 07:58:33
 Re: Diesel leak from injector pump, Help? in reply to Johnny Mac, 02-18-2006 13:31:06
Post back as to what brand of pump it is.
If a CAV, the fix is straight forward. Only need to get the EXACT size o-rings, 4 of them; 2 on each shaft: cut off and throttle. Problems are if you are not REALLY careful when removing the top cover, you will ruin the pump. 1. Clean, clean and clean again, the pump and all the area surrounding it. 2. lossen the cover and peek under it - - DO NOT remove it until you peek under and WRITE down the hole the "tombstone" shaped piece is hooked in. Then WRITE down the hole the other end in hooked in. The pump will not work right if you do not do this. 3. remove cover. 4 clean off old gasket. 5. Purchase new gasket and 4 o-rings from MF dealer. 6 reinstall with new gasket and new o-rings. You will need to exactly hook up the tombstone and shaft end of the linkage inside the cover like it was. A real good MF mechanic can tell you the tombstone and shaft-end hole settings from the complete serial number of the pump and model of MF tractor.
I done this repair on my MF-690 and completely stopped the dripping. It is so sealed that the pump hardly collects any dust now.
Sorry for long post.
Tom
Johnny Mac
02-25-2006 13:01:29
 Thankyou Tom in reply to TomTX, 02-19-2006 07:58:33
Goodaye Tom,
I ended up posting a reply to myself, which was meant to be sent to you.
Sorry about that, I"m not real good on these computers.
What I wanted to say Tom, is that you were one hundred percent right, about the leak and about the fix.
The old girl ain"t leaking no more.
So many thanks Tom,
Cheers for now,
Johnny Mac.
Johnny Mac
02-19-2006 12:18:02
 Re: Diesel leak from injector pump, Help? in reply to TomTX, 02-19-2006 07:58:33
Goodaye Tom,
Thankyou very much for your help, I,ll get the O rings and gasket today as I will be near a really good MF dealer today.
Thanks again Tom, I"ll let you know what happens, with the fix.
Cheers for now,
Johnny Mac
Johnny Mac
02-22-2006 05:10:52
 What Leak? in reply to Johnny Mac, 02-19-2006 12:18:02
Goodaye Tom,
I"ve gotta say, you were a hundred percent right, I did exactly what you said (I found getting the, "o" rings on tricky) and mate, it did the job, and I"m so rapted.
Thankyou very much Tom,
Johnny Mac.
J. Schwiebert
02-18-2006 14:22:46
Is this a CAV model DPA pump? If it is I think either your gasket is bad or the O-ring on the shut off shaft is bad.
Johnny Mac
02-25-2006 13:07:49
 Thanyou in reply to J. Schwiebert, 02-18-2006 14:22:46
Goodaye J.Schwiebert,
Just like to thankyou for your help.
Cheers for now,
Johnny Mac.
Johnny Mac
02-19-2006 12:32:53
 Re: Diesel leak from injector pump, Help? in reply to J. Schwiebert, 02-18-2006 14:22:46
Goodaye J Schwiebert,
Thankyou for your reply, I"m pretty sure it is a CAV pump, and I"ll find out today, when I visit the MF dealer. I will let you know how I went with the fix.
Cheers for now,
Johnny Mac
Johnny Mac
02-22-2006 05:15:59
 What Leak? in reply to Johnny Mac, 02-19-2006 12:32:53
Goodaye J. Schwiebert,
Thankyou for your help,
Problem solved.
Johnny Mac.
