Tool Talk Discussion Forum
fuel pump repair
in sticks
02-17-2006 17:33:24
on an old mech type fuel pump with the diaphram.anybody ever make a diaphram that worked? have a fuel pump that might need one? or a place to find new parts for pump?
TomTX
02-19-2006 08:01:49
 Re: fuel pump repair in reply to in sticks, 02-17-2006 17:33:24
Don't know about your model; but the repair kit for mine was almost as much as the new pump. New pump was reasonably priced and easy to install.
Tom
Jim@concordfarms.
02-18-2006 08:30:12
Not really much to go wrong except the diaphram and check valve. I did have one once that had a lot of wear on the arm where it touches the cam. Cut a 1/4" sq. piece of steel from a sickle section and had a neighbor w/ a TIG to weld it on the arm in the worn spot. They can"t pump if they don"t have enough motion. Jim.
kidbob
02-18-2006 07:47:07
I have a roll of diaphram material if you want to try to make one.
Slowpoke
02-18-2006 11:00:29
 Re: fuel pump repair in reply to kidbob, 02-18-2006 07:47:07
Just wondering where you got the diaphram material. I have searched the net with no results.
larry in tn
02-18-2006 06:39:34
Check your local NAPA dealer. NAPA amazes me with some of the items they have or can get.
Coloken
02-18-2006 06:22:37
No, don't think that is posible. But i have bought a pump that does not fit what i wanted and tore it apart to use rhe diaphram in my old pump. Don't know about new stuff, but in the old days most pumps were the same inside if they were the same make. Just kind of compared the size and looks. It was a Kaiser/Frazier car.
bradk
02-17-2006 19:00:17
Rebuild kits are effective and available,depending on what we are workin on? ~brad
