I just pulled this pressure washer out of the barn. I�ve searched over the net trying to find an owner�s manual, and came up empty. I�ve never used a pressure washer before, and could use some guidance from the knowledgeable folk on this board.Here�s the specifics: Bradson Model # PWV02013 2.0 GPM 2000 PSI Tecumseh 6.0 HP engine First off, does the pump use oil for lubrication? If so, does it use engine oil, or does it need a separate kind of oil? Attached is a picture of the underside, with the pump inlet and outlet. There are two round plastic plug-looking things, one yellow and one black. The yellow one rotated about a 1/4 turn by hand. I couldn�t get the black one to turn at all by hand. What are these? Are they plugs, or valves? How do I drain the engine oil out to change it? Anything else I need to know about operating or maintaining these things? Lastly, is this a decent pressure washer, or some Harbor Freight cheapie? [IMG]http://i19.photobucket.com/albums/b183/JUber/08691e72.jpg[/IMG][IMG]http://i19.photobucket.com/albums/b183/JUber/0159cfaa.jpg[/IMG][IMG]http://i19.photobucket.com/albums/b183/JUber/3d89eb7a.jpg[/IMG][IMG]http://i19.photobucket.com/albums/b183/JUber/4801c4e1.jpg[/IMG]
