Tool Talk Discussion Forum
Speedaire Model #3Z395 Compressor
Dan Eagen
02-14-2006 21:21:58
I was recently given this compressor (which I believe is approximately 30 years old) and was wondering if a tech manual is available from someplace for it. It runs great but seems low on oil. What weight oil is normally used in it? Any info would be helpful.
Thanks,
Dan
Coley
06-23-2007 08:18:54
 Re: Speedaire Model #3Z395 Compressor in reply to Dan Eagen, 02-14-2006 21:21:58
I have a 3z395, too. Do you still have the maual they emailed you? They can't seem to find mine in the system. Guess I'm talking to the wrong person.
Thanks
Coley
Lindsay
02-15-2006 08:50:50
I have an old Speedaire gasoline powered air compressor. It is a 3Z408 or something like that. I called Grainger and they emailed me a pdf document of the manual and parts diagram/
list with all the parts shown. Actually, I had to call them twice, because the first time I called the lady said that number was so old that it was not in her system, but I called back later and got a different lady who was able to find it and email me the manual and parts list. I was then able to order from them a rebuild kit for the pump which included gaskets, cylinder rings, and reed valves. It runs like new now. As far as the oil, I think the label on mine says use 30wt Nondetergent motor oil in the pump.
Dan Eagen
02-15-2006 18:55:10
 Re: Speedaire Model #3Z395 Compressor in reply to Lindsay, 02-15-2006 08:50:50
Thanks for the reply. I contacted Grainger and they sent me the info. needed. I also found out that the 30W nondetergent was the right oil.
Thanks again,
Dan
Charles (in GA)
02-15-2006 08:19:46
Doing a repair parts search by model number at www.grainger.com turns up nothing for 3Z395 so you need to call or email grainger.
Email or call Grainger Parts at 1-800-323-0620
Link
Charles
Dan Eagen
02-15-2006 21:02:03
 Re: Speedaire Model #3Z395 Compressor in reply to Charles (in GA), 02-15-2006 08:19:46
Charles:
Checked with Grainger and got all the info. I needed. Thanks for the tip.
Dan
Slowpoke
02-15-2006 00:17:37
That's a Grainger part number. Go to their web site and click on "Repair Parts". Don't let it run low on oil. Go to a compressor company and get the correct oil for it.
Dan Eagen
02-15-2006 21:04:55
 Re: Speedaire Model #3Z395 Compressor in reply to Slowpoke, 02-15-2006 00:17:37
Checked with Grainger & got all the info. I needed. Thanks for the help.
Dan
