Tool Talk Discussion Forum
V belt splicing
Robert in OR
02-14-2006 21:03:35
Is there anyway to splice V belts so they can be shortened? Perhaps a vucanizing process or cements?
Dave NE IA
02-15-2006 06:46:36
 Re: V belt splicing in reply to Robert in OR, 02-14-2006 21:03:35
Farm Tec has the put together belts, (www.FarmTek.com). If you can get them through Tek Supply they are lots lots cheaper, same building just depends if you use the East door or the West door. Tek Supply is dealer prices. Those sectioned belts are great for a spare belt, I use them on fan belts where to use a standard belt I would have to remove the hydrolic pump off the crankshaft etc. They are very extreemly long lasting belts, just alot of money a -- 6ft. is $39.95. Sometimes called power twist belts. Dave NE IA
Glen in TX
02-15-2006 04:39:47
I've had the belt splicers before and they were like a metal hinge and small screws went into the belt on each end of hinge and then a metal hinge pin inserted. It was just a emergency type thing to get by with till a new belt could be bought and had a special jig and tools to install the hinge on each size belt. Easier to just get a new belt and if needed carry a spare one. They make some variable link belts you make fit things by taking links apart putting together the length needed but those are about $25 + for a 4 or 5 Ft. length.
BOBinWA
02-15-2006 07:57:44
 Re: V belt splicing in reply to Glen in TX, 02-15-2006 04:39:47
That hinge thing is what I am looking for. If anyone remembers where they came from please post it. Thanks
Glen in TX
02-16-2006 08:14:11
 Re: V belt splicing in reply to BOBinWA, 02-15-2006 07:57:44
I got my splicer at a auction cheap. The stupid thing cost too much new and they told me the blade for my applicator is obsolete because they changed to a new hinge and have to buy new system. I could buy lots of belts for that!
Make my own blades....
Glen in TX
02-15-2006 14:08:39
Bob,
They were called "Flex V Belt Fasteners" for A & B v belts. Trimming tool, Alligator V belt cutter and hinge belt fasteners made by Flexible Steel Lacing Co., Chicago, IL.
I need some blades for my B size trimming tool if anyone finds parts for these.
Glen in TX
02-15-2006 13:12:50
Bob, I'll look to see if I can find it again and what the brand name is. The one I have is just for B size V belts but seems like I broke something on the trimming jig for it. It doesn't work well for something that needs to start and stop often as the pin on hinge can fall out too easy. I tried splicing a mower belt once with it and when you stopped the pin fell out. Graingers and many industrial bearing supply places sell those link belts also.
old
02-14-2006 21:26:05
They usto make a belt that would bolt togeather but don't know if you can still find them. Other then that I have never seen one. Why not just buy the correct size belt??
Slowpoke
02-15-2006 00:09:10
 Re: V belt splicing in reply to old, 02-14-2006 21:26:05
They're called emergency v belts. You can make any size up to the maximum. Check JC Whitney catalog or web site. They cost more than the correct size belt.
