Tool Talk Discussion Forum
Killing Powder Post Beetles
Beanscoot on Va
02-11-2006 19:40:19
Hi Robert, I would place the infested article in a reasonably air-tight container like a milk crate wrapped in heavy plastic. Place a pan with a half inch of full strength formaldehyde on the bottom and use some kind of spacers in the pan to support the wood above. A couple days in this little gas chamber should kill anything. Purchase formaldehyde at a farm supply store, or if unobtainable, I would guess ammonia would work. Be thankful that the beetles are in a lamp and not in your house's floor joists and subfloor (like mine).
Beanscoot
02-11-2006 19:45:55
 Re: Killing Powder Post Beetles in reply to Beanscoot on Vancouver Is, 02-11-2006 19:40:19
Hi Robert, I just realized that you probably mean 6x6 feet, not inches. Anyhow, build your gas chamber of 2x4s and heavy polyethylene film to fit, or use a sealed up garden shed, and lots more formaldehyde. Another fumigant the old timers used was a big block of sulphur set on fire. They used to fumigate whole houses this way (and probably burnt down a few). The sulpurous fumes should dissipate after a long time.
Johnbob
02-12-2006 13:44:46
 Re: Killing Powder Post Beetles in reply to Beanscoot, 02-11-2006 19:45:55
I was talking to a fellow that ran a sawmill and he said to leave it out in sun for a few days.They are unable to take the sun.
stacarp
02-12-2006 16:54:11
 Re: Killing Powder Post Beetles in reply to Johnbob, 02-12-2006 13:44:46
try this link it may help
http://ohioline.osu.edu/hyg-fact/2000/2090.html
bug killing
02-13-2006 07:45:00
 Re: Killing Powder Post Beetles in reply to stacarp, 02-12-2006 16:54:11
If there is a sawmill near by with a kiln. You could ask if they would put it in there next pitch drying bug killing cycle. I can't imagine them charging you more than 10 bucks but then you never know. Basically the kiln will heat up to 160 degrees F for 24 - 48 hours. Kills the nasties in the wood should not hurt your piece of lumber. Benefit no chemicals.
