Tool Talk Discussion Forum
jonsered 520 fuel lines
rod s
02-11-2006 12:45:27
Hi I have a jonsered 520 chainsaw can someone tell me how the fuel lines go there is one out of the tank to the left side of saw and one that goes around the saw to the top is this correct the lines may have been cut since I got it this way, also there is a rubber grommet on one line that is missing and the saw does not seem to want to pull gas up to carb if you pour gas in it will run fine till gas is gone any diagram will help.
regards
rod
Joel Harman
02-11-2006 14:54:23
 Re: jonsered 520 fuel lines in reply to rod s, 02-11-2006 12:45:27
there is a filter on end of line in gas tank...change it.
rod s
02-11-2006 15:03:24
 Re: jonsered 520 fuel lines in reply to Joel Harman, 02-11-2006 14:54:23
the problem seems to be the return line from the top of the carb if I can figure out that I might get it to work the line was cut and I am not sure where it goes a pic or tell me where the line runs would be great.
regards
rod
