I would think that would it would be worth taking, unless the material is scaling heavy rust flakes off. I used to be involved on high rise projects in NYC and been around quite a bit of reinforced concrete structures, building components etc. I don't ever recall seeing lap joints being welded, or called for on structural drawings etc., also have to be careful when field cutting steel with a torch although that applies more to structural shapes and connections, the rationale behind it is of the same concern, brittleness, which I can agree might be an issue with welding bar of that size. With the amount of joints that get tied, it would be insane to weld as no one could work close to you. They usually set up a machine that shears and bends the rebar and the Lathers do all the fabricating, tying of the joints and installation inside the form. I can also see the Inspection controls needed when field welded joints are concerned, In NYC, a licensed professional engineer has to inspect and sign off on a technical responsibilty report for all structural connections, especially welded joints, they even go to the steel fabricator to inspect fabricated sections etc. It sounds ridiculus but it's done for good reason, and if properly done from beginning to end on a project, it's no hinderance to the production. Way off here, back to reality as this is for the "Skyscrapers" and like, a lot of the rebar that is placed can be seen with no blue left on it, is rusty, just not corroded with heavy flakes peeling off, I would use that material, tie off the 150 joints you appear to have, use the setting chairs, maker sure the bar has enough coverage above and below, ideally 3" both sides with a 6" slab, but as best can be done. I am a fan of reinforcing, be it rebar and 6"x6" woven wire mesh, W.W.M. the latter I would think in conjunction with fibre admixtures, ought to be a good slab mix, not sure what kind of loading you can get away with, but it's interesting to hear about how it's performed for all the people who write about it here, I've never done a lot with the fibre admixtures. The only concern with regular rebar, not galvanized, epoxy coated or what have you is that concrete has capillaries that allow fluid to seep in, if it is corrosive, and reacts with the rebar, it will expand the steel 3x its size and spall the concrete, as what happened to older bridge decks due to salt used in the winter. Don't mind me lately I'm full of all kinds of wondering babble, overkill etc. LOL, but it sounds like a decent deal I'd use it without hesistation.
