Tool Talk Discussion Forum
Bandsaw or power hacksaw
oj
02-09-2006 21:34:59
I can't decide between a bandsaw or a power hacksaw for my shop. I currently use a chopsaw, but the dust/sparks etc. are making it unplesant to work with. I also need a machine capable of cuttting 6x6 square steel tubing for an upcoming project. Most of the work that it will be expected to do involves lighter material. Any idea which machine would be better?
Tim Casbolt
02-11-2006 17:37:37
 Re: Bandsaw or power hacksaw in reply to oj, 02-09-2006 21:34:59
I share the same dilemna. A horizontal has no length limitation and makes straighter cuts, but a vertical can be used to cut shapes when necessary, and takes up less space. What I would like is an industrial quality combination horizontal/vertical, but have never seen one other than the homeowner quality combos that are not rugged enough for serious metal cutting.
RickL
02-12-2006 01:37:04
 Re: Bandsaw or power hacksaw in reply to Tim Casbolt, 02-11-2006 17:37:37
Ellis makes a unit
Tim Casbolt
02-12-2006 04:19:16
 Re: Bandsaw or power hacksaw in reply to RickL, 02-12-2006 01:37:04
RickL, Do you have any more information about Ellis? I Googled it and didn't come up with any equipment manufacturers.
RickL
02-12-2006 06:48:42
 Re: Bandsaw or power hacksaw in reply to Tim Casbolt, 02-12-2006 04:19:16
they are there own company,see what I can find as I need to order blades again anyway. really been nice machine for me.
dave2pa
02-11-2006 13:59:28
If you watch ebay maybe you can find a Power hack saw close enough to pick up. I have one and the are great ,,Blades are no Problem either .lenox makes them,
watch ebay for a band saw also ,I bought a VERTICAL one on there went 200 miles to get it but well worth it .
oj
02-11-2006 13:44:05
thanks all. i'll have to start looking for a bandsaw
ben a
02-11-2006 10:27:58
Fein make a good power hacksaw. Available in pneumatic and electric. Ive used one before, never owned one and it cut well. If it as good of a tool as the multimaster, it will be well worth the money.good luck
RickL
02-10-2006 05:38:39
Been ther done that with the chop saws. I know have a bandsaw one of best things in the shop. Ellis dry cut style is what I have and love it.12x12 max cut swing head for angle etc. Blades last me around two years. Simply loved it. Plasma cutters are nice ( I just sold mine couple months ago) but no way do they replace a band saw.
mjbrown
02-10-2006 03:24:47
Have you tried a plasma cutter? I don't own one but I learned to use one in a welding class. I was impressed. Clean cuts and you can make patterns from cardboard or plywood, lay pattern on steel and cut.
Charles (in GA)
02-10-2006 02:14:47
A bandsaw is about the best investment you can make for a shop tool. I have used my little cheapie Northern bandsaw for just about everything you can imagine, from cutting angle iron to cutting elect conduit to cutting large size pvc pipe. Bandsaw hands down.
Charles
Slowpoke
02-09-2006 23:13:32
I think power hacksaws are about obsolete. Have you found a source for replacement blades?
ldj
02-10-2006 06:43:55
 Re: Bandsaw or power hacksaw in reply to Slowpoke, 02-09-2006 23:13:32
Type in "power hacksaw blade" at e-bay and you will find then
