Tool Talk Discussion Forum
rotation of 220v motor
woodbutcher
02-08-2006 17:13:51
I have the same question unioncreek asked two days ago. To reverse the rotation of a 220v motor that does not show a way to reverse it on the wiring diagram, what can be done? The new
tank I bought is laid out in reverse of the old one, and the motor will turn the compressor backward unless I can reverse the rotation. It is a capacitor start motor.
Leland
02-08-2006 20:45:21
 Re: rotation of 220v motor in reply to woodbutcher, 02-08-2006 17:13:51
need motor brand and motor number to give correct answer .
bigwood
02-08-2006 18:45:46
Inter-change #5& #8 if motor is reversable.
Brand0n
02-08-2006 17:51:38
To reverse the rotation of a single phase motor one simply has to reverse the connections to the starting winding thus reversing the magnetic phase that is imposed across the rotor during start-up. The run windings will be the thicker of the coils and follow all the way to the power terminals, maybe through a thermal overload while the start windings will be thinner coils that are 45 degrees offset from the main run coils and they follow through the start capacitor and cut-out switch located on the rear bearing bell. A 3 phase motor requires the reversal of any L connection however some 3 phase motors do not like to run in the opposing direction.
Be careful and play it safe that capacitor packs a solid punch!
Brandon
buickanddeere
02-09-2006 21:38:43
 Re: rotation of 220v motor in reply to Brand0n, 02-08-2006 17:51:38
Correct.
woodbutcher
02-09-2006 04:56:47
Thanks to all, and especially BrandOn. This will be helpful.
Butch
smilie
02-08-2006 17:49:18
reverse the wires on the L1 and L2 terminals of the motor and that should so the job.
Brand0n
02-08-2006 18:15:48
 Re: rotation of 220v motor in reply to smilie, 02-08-2006 17:49:18
Hey this isn't Smilie Dean that I know from the minneapolis area is it?
smilie
02-08-2006 18:34:01
 Re: rotation of 220v motor in reply to Brand0n, 02-08-2006 18:15:48
nope. northern illinois, sorry
