Tool Talk Discussion Forum
What type power steering fluid is used on Ford car
Midwest redneck
02-07-2006 14:29:27
I need to know what type of fluid is used on the Ford power steering systems, it will have a # like M2C2B (that used to be the fluid anyway) does anybody here work at a Ford Dealer and know the exact #. Thanks.
Brand0n
02-08-2006 17:58:06
 Re: What type power steering fluid is used on Ford in reply to Midwest redneck, 02-07-2006 14:29:27
Be careful with that Mercon fluid as I have had troubles in the past with leaky seals on Saginaw steering gears. Im not sure what has changed with the Dexron-III Mercon type oils but I understand its a semi-synthetic fluid and will swell up neoprene seals.
On the older car I would go with the old Type-F oil or real power steering fluid that is nothing more than overpriced 10 weight dino oil. Both of my cars use standard 10 weight hydraulic oil and none of them leak, one ford ranger 2.9L with the ford plastic power steering pump and my Volvo Turbo-diesel that uses a saginaw GM steering pump.
Brandon
bradk
02-07-2006 18:00:52
Hey redneck; XT-2-QDX (mercon)~brad
Charles (in GA)
02-07-2006 15:54:50
Older ones use Type F auto tranny fluid. Not sure what they do nowdays.
I think Ford has caved in completely and recommend Mercon (GM's Dextron) for all of their auto trannys, old and new. They got goofy in the early 80's. My dad bought a new '84 LTD (small car) with a C5 trans. It was speced out with type H fluid. First time we went to change it, couldn't find any type H, no one ever heard of it, finally found out they had quickly superseded it with Mercon/Dextron.
Charles
