NC Wayne
02-06-2006 18:28:38
Re: ASME on Tank ? in reply to Andy in NC, 02-06-2006 16:59:31
I've also read the same posts and I agree that an expoding tank, of any type, is a dangerous thing. That said, why exactly have you decided to replace yours? If it's starting to develope cracks, etc then I agree it's time, heck beyond time, to replace it. If however your doing it just because it's 15 years old then, in my opinion, your simply wasting your money. I've worked around air compressors all my life and have seen tanks that are over 40 years old that are still in service and under pressure every day. Many of the tanks were in businesses where they had to have a state inspection "pressure vessel" sticker on them and they never failed to pass for the sticker. Unless a tank has visible physical damage, like dents, cracks, rust holes nearly through it, etc then it's still safely usable. Heck even a rust hole isn't likely to cause a rupture, usually they just leak and keep the compressor running trying to keep up. The tanks I've heard of rupturing over the years were typically not really "the tanks fault". It is usually a combination of factors, a stuck safety valve and an inoperative/defective pressure switch on the compressor, somebody running into it with a forklift, or something along those lines. If your tank is still in good shape there's no reaon to get rid of it. Heck the way quality control is nowdays the chances of a tank coming off the line with problems that could cause it to burst are probably higher than they were 15 years ago. Either way your gonna have a minimum of a 50/50 chance of something happening, either the tank is good or it isn't. The only way to know 100% for sure would be to have it hydro tested which really isn't a feasible thing for a tank on a personal compressor. Basically if there are signs it needs replacing other than just the age then do so, otherwise, keep the water drained to help prevent internal rusting, make sure the safety valve and your comoressors unloading valve or pressure switch is working and save your money for something else you really need. Just my .02
