"Simply heat your base metal just as you would for fusing two pieces together (molten puddle stage) and add the bronze into the weld pool." NO, no, no. You only want to heat the base metal hot enough to melt the bronze. If you melt the base metal, you are too hot unless the base is also bronze or brass. Overheating is typically the problem when brazing while too cold is generally the problem with welding. Overheating will cause the bronze to contaminate the steel or, in the case of cast iron, will cause it to form brittle and hard cast iron. That is a guaranteed break, right at the edge of the joint. Brazing and welding are two totally different operations and require different techniques, materials and skills. Brazing will require a flux or a flux coated rod. The bronze will melt at a temperature about 500 degrees less than the base metal. Brazing is more similar to electronic component soldering. You flux the joint, which chemically cleans the work and allows it to "tin", in which the bronze will flow out over a wide area, called "wetting". Once tinned, the braze can be built up to a thicker section. Yes, torch distance is a form of heat control, but that movement range is limited to about 1/4". The weld area must be inside the flame envelope to prevent exposure to the atmosphere and contamination/oxidation. If you cannot control the torch within this range, change tips or crank up the gas. When brazing this is not such a consideration because the base metal will not be actually melted and the flux will maintain a proper atmosphere for the bronze. You can move the torch back a lot further in this situation to control the heat. 1/8" steel filler rod is normally used for welding .032 tubing or sheet with OA. Thinner rod requires too high a filler feed rate and can result in a thin weld section, a point of weakness. The rod is also an important heat control tool. Adding filler or just holding the rod over a hot spot will cool that area down.
