Tool Talk Discussion Forum
Cutting bolt holes in gasket material
Buck D.
02-05-2006 12:11:28
I'm working on a project that requires me to make my own gaskets.Is there any tool to cut perfect bolt holes in these gaskets? I think I need 1/4 inch holes.(alot of them).Thanks
Georgia Boy
02-07-2006 09:59:18
 Re: Cutting bolt holes in gasket material in reply to Buck D., 02-05-2006 12:11:28
I got a set of hollow punches off eBay that have served me well making gaskets. When they are sharp they should cut through even tough material like leather.
vjd
02-06-2006 19:33:20
Take an old golf club steel shaft an cut it to the size you need.
Buck D.
02-06-2006 14:55:37
Thank you guys for all the good ideas.I'm all set now!
CASEPOWER
02-05-2006 22:34:50
Use spent rifle or pistol shells. They come in a lot of different diameters and work great. It takes a little while to get a good selection, but they will last a long time.
Don L C
02-05-2006 21:02:30
Most tool supply stores (SEARS)sells them by the set, like drill bits....just place the punch where you want the hole tap with hammer..... .you got it....they dont cost much $$$
bison
02-05-2006 19:51:15
Use a ball bearing , as long as it is bigger than the hole. push it down a bit in to the gasket over the hole so it stays ,give it a rap with the hammer and you have a perfect fitting hole. it is all I use. No need for all them dif size punches
MarkB_MI
02-05-2006 18:27:08
Assuming the part is cast iron or steel (and not aluminum), a small ball peen hammer is all you need. You do need to punch a couple of holes to start, use whatever you have (knife, leather punch, etc.) Then secure your gasket material to the part with a couple of bolts and start tapping. Perfect gasket every time.
Ken in Mich
02-05-2006 17:43:50
I often used to make gaskets for heavy machinery at work. We had the gasket punches, but nobody used them. It was much quicker/easier to use the drill press with the appropriate drill bit, put a block of wood underneath. Also, we didn't use the gasket cutters... electric or air sheet metal nibblers worked much better.
buckva
02-05-2006 16:22:50
Lay the gasket material on the surface you need the gasket for and peck the holes out with the round side of a ball pean hammer
Earl in KY
02-05-2006 16:20:20
Come on gents, Were are all the old timers????
Remember the Ball peen hammer method ?????
CRUSADER
02-07-2006 21:10:55
 Re: Cutting bolt holes in gasket material in reply to Earl in KY, 02-05-2006 16:20:20
I'm not an "old timer" but have made more than a few gaskets with a small ball peen (aka gasket) hammer.
mj
02-05-2006 18:11:58
Yeah, a ball pein or the right size (bigger than the hole) ball bearing and any old hammer.
Irv (Ia)
02-07-2006 13:15:51
 Re: Cutting bolt holes in gasket material in reply to mj, 02-05-2006 18:11:58
Yep, bearing balls work good. Got a drawer full of different sizes. I've used those gasket punches too--found out they work good in the drill press on slow speed for certain things. A little lubricant on the tip, soft wood underneath and no damage to the punch from hitting it too hard.
Irv
wrench400
02-05-2006 16:05:12
Hole punch like a hand ticket punch.Perfict for 1/4 inch holes.Found in office and school supplies.I think I got mine at the $1 store.
Lloyd Llama
02-05-2006 14:40:38
Leather punches - sold in many hardware stores, and craft stores.
Midwest redneck
02-05-2006 14:12:45
Get a ball bearing (oversize from the hole you want) and put the gasket over the hole and use the ball bearing and a hammer to tap hole threw the gasket, it works very well, you will need an exacto blade for cleanup. Have fun.
mj
02-05-2006 18:17:18
 Re: Cutting bolt holes in gasket material in reply to Midwest redneck, 02-05-2006 14:12:45
You said it, I said it, THEN I read what you said so I shouldn't have said it (you already did)..... ..Right? :-)
Ryan - WI
02-05-2006 14:07:23
I just use a pipe sharpened to about a 45 degree angle on the belt sander. Use a block and sharpen if necessary.
Steve Crum
02-05-2006 14:00:40
Bought 2 sets of hollow punches off fleabay. These punch 1/8" to 3/4" Made in China but 6 bucks each set and 5 bucks shipping. Looked at a set of Greenlee hollow punches 87 bucks. The cheap Chinese punches have done all I need to do.
F-I-T
02-06-2006 06:23:49
 Re: Cutting bolt holes in gasket material in reply to Steve Crum, 02-05-2006 14:00:40
third party image
Sme for me. Any number on eBay at any time for under $20. Some are pretty nice.
Steve Crum
02-06-2006 06:52:27
 Re: Cutting bolt holes in gasket material in reply to F-I-T, 02-06-2006 06:23:49
Hey! That's just like the sets I bought! Would have perfered American made, but couldn't justify the cost, 6 bucks new vs. 87 bucks.
TimV
02-05-2006 12:58:58
Buck: You can buy special gasket punches, but many times it works well to use old cartridge cases--a 1/4" bolt hole would be a bit larger than .25 inches, so a .270, 30-06, 30-30 or similar should be just about right. Sharpen the edge a bit on a belt sander, use a wooden backing block so you don"t roll the edge over, and you should be good to go.
Davis In SC
02-05-2006 17:49:33
 Re: Cutting bolt holes in gasket material in reply to TimV, 02-05-2006 12:58:58
Tim, thanks for that idea... I never thought of it... Disclaimer: Never use primed cases, LOL
TimV
02-05-2006 21:16:58
 Re: Cutting bolt holes in gasket material in reply to Davis In SC, 02-05-2006 17:49:33
No problem--lots of guys have brass around, and so you don"t usually have to look far to find a lifetime supply of punch cutters--at least in the smaller sizes. .38/.357 cases work great for 3/8" bolts, and .45 ACP works good for 7/16". On holes much larger than that, it"s usually quick work to sharpen the edge of an appropriately-sized chunk of pipe and punch away.
NC Wayne
02-05-2006 20:01:44
Ah, come on, the ones with the primer left in them solve the problem of how to dig the punched pieces out when they get built up inside...LOL
Larry-Tx
02-05-2006 12:37:46
Harbor Freight item 6770-ovga set for $16.99
msb
02-05-2006 18:49:02
 Re: Cutting bolt holes in gasket material in reply to Larry-Tx, 02-05-2006 12:37:46
Have a set of them from Harbor freight.They work great.
old
02-05-2006 12:32:31
They make speacial punches just for doing that. I have 2 or 3 of them but I don't know where to find them. You might ask at a parts store.
Bilko
02-05-2006 12:15:39
Buck,
Type in the word gasket punch in you search engine. I just did and found alot of them at ebay, and the prices aren"t bad. Hope this helps.
Mike from MI
