Tool Talk Discussion Forum
O/T HOMELITE TRASH PUMP
HUSKY
02-05-2006 11:04:25
HI NEED SOME HELP I HAVE A HOMELITE 200GPM TRASH PUMP I NEED TO FIND A HAND STARTER FOR IT ANY IDEAS WHERE I CAN FIND ONE ??? THIS IS AN OLD ONE NO ###s EXCEPT 53248 ON PUMP AND 54539 on THE AIR FILTER COVER ANY HELP APPRICIATED THANK YOU
Roy Suomi
02-06-2006 20:18:51
 Re: O/T HOMELITE TRASH PUMP in reply to HUSKY, 02-05-2006 11:04:25
If your unit is an old 2 stroke [ green ] pump I might have one out in my barn . It's been years since I've seen it but,It's out there [email protected]
NC Wayne
02-05-2006 20:09:23
I know the feeling when you need a part and the oh so important numbers are nowhere to be found. it seems like more and more mfgs are putting those cheap a-- printed stickers on things nowdays and the when the ink wears off it's all over but the cussing. Is there any way you can post a pic so we can see what you've got? I've got a good many small engines lying around that I've picked up over the years just for parts. Many of them came from a big construction company that repaired alot of their own equipment and some of them, judging by the crank design, came off pumps, so if I could see what your needing I just might have something for you.
NC Wayne
02-05-2006 20:08:41
jdemaris
02-05-2006 15:21:21
Is this pump all metal with a rope starter, or is the pump housing plastic and the engine equipped with a recoil starter, or some other combination? The old Homelite 19S2 pumps have Homelite 2-stroke cycle engines, whereas the newer units often have Briggs & Stratton engines, Wisconsin, Subaru, Honda, etc. Some of the big mud pumps have Wisconsin Robin 2 stroke cycle engines that are made by Subaru. I don't know if what you have is a trash/mud pump or a diaphram/centrifugal water pump. My Homelite FP-250 is a 200 GPM pump is called a 2" pump because it takes a 2" hose. It has a 10 horse cast-iron Briggs. Some of the newest Homelite pumps in the 150-200 GPM range use Honda engines. Recoil starter parts are easy to get under the engine brand name.
HUSKY
02-05-2006 19:14:27
 Re: O/T HOMELITE TRASH PUMP in reply to jdemaris, 02-05-2006 15:21:21
IT IS ALL METAL I NEED A RECOIL STARTER FOR IT AND IT IS 2CYCLE RECOIL STARTER IS M.I.A. ANY IDEAS WHERE TO GET ONE LOCAL DEALER IS OF NO HELP LAUGHED WHEN I MENTIONED NEEDING A STARTER????? ?
rustyj14
02-05-2006 11:56:36
We need the make and engine numbers of the engine! Those numbers are on the flywheel housing, if either Briggs or Tecumseh! Will be: code, type, ser., numbers like that!
HUSKY
02-05-2006 13:23:57
 Re: O/T HOMELITE TRASH PUMP in reply to rustyj14, 02-05-2006 11:56:36
I DONT SEE ANY ### ON IT OTHER THAN WHAT I TOLD YOU I WILL TAKE OFF THE HOUSING A LITTLE LATER THIS WEEK
