Tool Talk Discussion Forum
air tank for air compressor
hogman_2002
02-03-2006 09:44:19
I've got an air compressor with a 30 gallon tank. The tank is cracked and I have tried to weld it but haven't had any luck. So I figure I'd just replace the tank so I won't have to worry about it leaking anymore. I looked on the internet but haven't found what I need. Does anybody know of place that sells air tanks for a reasonable price? The tank needs to be a horizontal one with mounts on the top for the motor and compressor.
Thanks
graygander
02-05-2006 16:35:17
 Re: air tank for air compressor in reply to hogman_2002, 02-03-2006 09:44:19
I have the same problem with a rusted out tank. Surplus Center has them, but they aint cheap. So far no luck finding a good used one either. Beware of the new direct drive and oiless compressors, I"ve been told their no good. I will more than likely just buy the new tank and be done with it. Good luck
Charles (in GA)
02-03-2006 17:36:50
Get a new tank, too dangerous to try to repair this one.
Try www.surpluscenter.com for an air tank for a compressor, they have manufacturers surplus, end of production run leftovers, etc.
Charles
John A.
02-03-2006 15:55:50
Hogman, I am with Rusty on this one. Even if you succeed in getting it welded up there is a good proibility the tank will fail later. So STOP now! go to WW granger company. They should have a replacement tank for it. But on the other hand it may only cost alittle more to go with a new one.
Again do not use a welded tank. They will rust and corrode on the inside and will sooner-or-later fail.
One post of late on one of the threads here told of a compressor that blew up and went through a celing, 2x6s and all, luckly no one was around.
Better to tell us about the new compressor than to have your wife have to tell us about your funeral!!!
Later,
John A.
Ralph - Ohio
02-03-2006 12:39:29
I don't know where you are but there used to be a fellow near Columbus, Ohio who sold lots of good looking used tanks on eBay.
Glen in TX
02-03-2006 12:33:41
Find out where a local military surplus contractor is at in your area. You won't believe what they throw away and I've found 2 almost new air tanks that way. Others that sell new:
www.grainger.com
Chris Jones
02-03-2006 10:47:20
Start looking for another compressor with a burnt up motor but a good tank. :)
Ask if anyone is throwing away one on www.freecycle.org or www.craigslist.org.
People throw the most amazing stuff away. :)
Jerry/MT
02-03-2006 10:35:49
I agree with Rusty. When my tank rusted out (and I drained after each use!), I looked for a replacement tank and it cost more than what I paid for the whole unit. I ended up buying a new unit. It's too bad because my compressor was in such good shape. Repairing the tank is risky because if the repair fails it could be fatal for anybody near it. Better to be safe than sorry.
RustyFarmall
02-03-2006 10:28:25
Attempting to repair a rusted out or otherwise damaged compressed air tank is never a good idea. I have seen the results of what happened when a repair was made to a tank and then the repair failed with a full tank of air. Luckily in that case no one was injured, simply because no one was in the shop when the tank exploded. The tank on my small portable compressor rusted out several years ago. I went shopping for a new tank, and quickly learned that I could buy a complete new unit in a bigger size for not too much more money.
