Tool Talk Discussion Forum
Valve grinding machine
REDJD
02-03-2006 07:57:55
Anybody know how much a valve and seat grinding machine cost & who sells them? Something for a small shop.
JD9295
02-04-2006 22:03:06
 Re: Valve grinding machine in reply to REDJD, 02-03-2006 07:57:55
one for sale in the photo adds
jdemaris
02-03-2006 20:36:09
If you want to buy a "fixer upper", I'd sell a Sioux valve refacer at a good price. It's one of the later models, wet machine with separate motors for the valve chuck and grinding wheel. I say "fixer upper" because is was damaged, mostly to the electric control panel. It needs some wiring, but the important parts are fine. I happened to be present at a place where the New York State Department of Transportation was destroying the contents of an entire machine shop instead of selling off the equipment - our tax dollars at work. They destroyed milling machines, drill presses, hydraulic presses, complete valve refacing kits, diesel generators, etc. Also, they had hundreds of unopened boxes of diamond dressers, Sioux stones, Sunnen hones, mandrels, etc. I was able to grab a few things that weren't destroyed - actually I filled my pickup truck - but there was enough there fill 20 trucks. The valve machine has been sitting in the corner of my shop for five years collecting dust. The machine is VERY heavy and not worth trying to ship. I have no need for it since I've already got two valve refacing machines, two valve seat cutting sets (stones), and two Newway sets (carbide cutters). I've also got a Sioux air-powered valve seat grinder that came from the State stuff, but no mandrels or stones for it. For home shop use, a dry machine will work fine like an old Sioux or Black & Decker. They seem to last forever, and work great if you make them "wet" with a hand-held squirt can. They can usually be had in the $150 - $300 price range.
Slowpoke
02-06-2006 02:26:50
 Re: Valve grinding machine in reply to jdemaris, 02-03-2006 20:36:09
Here's another one to make a taxpayer sick....
I went to a recycle place to turn in some scrap wire. There were large piles of various kinds of metal scrap including one pile of aluminum step and extension ladders. About 50-60 in the pile. Some were used and some were brand new and still had the shipping material wrapped around the feet/shoes... I saw a new 28' ladder so I asked about buying it and was told they were purchased from a county agency as scrap and had to be destroyed. More of your tax dollars at work.
REDJD
02-03-2006 15:23:58
Thanks guys for all the info. I had tried to do a search on valve grinding machines but none of the sites that came up gave a price.I should be able to find what I'm looking for with all the info yall gave me.I'm retired now and have a lot of projects to work on plus some projects of some friends.The nearest machine shop is about 50 miles from my house so I would like to do as much as I can in my shop. Thanks again
Old Dutch
02-03-2006 13:33:18
REDJD: If you are looking for something for Small Engines,or even larger engines, why not check out New Way. They have some very good tools for doing seats, valves plus narrowing seats. They have very good equipment. I have used their tools for years. Very good company to deal with. Their seat cutters, and valve refacers are all made from the best carbide steel, and if used and not abused will last almost forever. Much better than the Snap-on, and Sioux valve machine I worked with 20+ years ago. You'r not having to constantly having to true up stones and what have you. Check them out at Neway.com.
Tractorman1
02-03-2006 14:24:03
 Re: Valve grinding machine in reply to Old Dutch, 02-03-2006 13:33:18
Use this site for Neway.
http://www.newaymfg.com/ If you just put in "neway" you get a large truck equipment company, interesting, but they do not sell valve repair equipment.
Glen in TX
02-03-2006 12:30:30
www.farrisequipment.com
www.regismfg.com
RustyFarmall
02-03-2006 10:17:23
Used machines will easily bring $300 to $400 and higher. A Black and Decker machine just like the one I have been trying to sell sold for $345 on E Bay about 2 days ago. I have provided a link to a company that sells new engine rebuilding equipment.
Butch(OH)
02-03-2006 08:27:32
Sioux, Kwik Way, Black&Decker, and Snap-On used to the big names in that line of equipment. I am pretty sure that B&D is of it now. Try a search id bet all those people have web pages. I am not sure about current pricing but I can tell you that new is probably out of the range of a home or low volume shop. Complete and decent condition seat grinding setups sell $3-800 at auction around here. Valve facing machines about the same. Be very carefull about used tools as play developes in the spuds, stone holders etc and sloppy seat equipment is next to usless as is a worn out valve facing machine.
butch h
02-05-2006 16:23:26
 Re: Valve grinding machine in reply to Butch(OH), 02-03-2006 08:27:32
Back when I was a younger fellow I had a burned valve in my 221 c.i.d.Mercury Meteor.I took it to a machine shop,and the old boy chucked into a lathe and cut it better than a grinder would.
