Tool Talk Discussion Forum
Steel roofing questions
scott#2
02-01-2006 17:44:47
Im building a 24 x 36 run in slant roof shed to keep tractors in. I wanted to use steel roofing on lattice, setting on 2 x 10 rafters, spaced 18" or so. I would like to get 3, 12 foot openings. There will be 12, 6 x 6 poles in the ground for support. I really want to keep the top light so I can get the 12" spans between poles. I live in Maryland. so snow load really isnt a factor. I have NO experience with steel panels and wonder if anyone out there could fill me in on this topic. Cost, sources, lengths, assembly, under support, what ever you know about it. I dont need anything fancy, just plain old galvanized will do, something with a decent lifespan would be nice. Any help is most welcome.
Thank You,
scott#2
Don L C
02-03-2006 21:08:21
 Re: Steel roofing questions in reply to scott#2, 02-01-2006 17:44:47
I need to build 3 small buildings this spring:
1) 20'x20'lean too on the side of my shop...shop is regular consruction block on concrete footers....reg wood walls.....should I use pole construction on addition ?
2) 20'x20' car port next to wood Deck at the back of the house..... .pole construction OK ?
3) small 8'x12' wood green house with windows in the roof.....pole construction OK ?
How long would you expect the poles to last in the ground ?
All with crushed stone floor....how do I layor the floor ? Thanks Don S W Ohio
John Niolon
02-03-2006 04:23:13
look in the yellow pages for "metal sheeting" or metal roofing. We have a company close by that makes the side wall and roof sheets for Butler style buildings... also forms the purlins/girts.
I buy galvalume 029 gauge for 1.50 per ft. 36" wide...26 gauge is 1.80 per ft. They will roll and cut any length you want for no extra charge.
john
Byron Sellers
02-02-2006 08:15:42
You might go to your local home center, Lowes, Home Depot, Menards etc. They will help you plan your building for free, on the computer. This will or should be designed for your area and you can price your tin, etc at the same time.
I had Menards work up my building on the computer just the way I wanted it,got an estimate and then didn't buy until a year later. The computer will tell you what you need for rafters on your span etc. And you can use your own poles or what ever you want.
jack12345
02-01-2006 21:16:29
Make sure you use straps on your 2X10,s as wind can make a sail out of a roof that size. Also remember it only takes alittle snow and rain to do your roof in if it does not shed snow. To be on the safe side build it strong if the pitch is 5/12 or less. where it sits is important too if in shade and gets leafs on tin you want a 6/12. out in the open with sun 5/12 works great..Im always happy to see that snow go off the tin on my sheds. I use gravel 3"& less for stalls pack in then crush on top of that for base. put the 3" down befor anything lot easier to work with if you dont have to work arourd all those posts.Check with local sawmills they may cut sizes just what you need and save you money over Lowes ETC
Don L C
02-03-2006 21:10:47
 Re: Steel roofing questions in reply to jack12345, 02-01-2006 21:16:29
SORRY... I SHOULD HAVE POSTED MINE SEPERATE
DON SW Ohio
