Stripped Threads.
AWB
02-20-2001 18:44:57
I have a casting which has 4 bolt holes with stripped threads....How do I fix this problem? Going to a larger size bolt is not an option in this case. Thanks.
popcornsteve
02-20-2001 18:56:33
 Re: Stripped Threads. in reply to AWB, 02-20-2001 18:44:57
What size threaded hole are we talking? Is there room in the casting to drill the old holes out? If so, you can get what are called Keen-Inserts which are small inserts threaded inside and out. The inside will be the thread size you need, and the outside will be a larger diameter. After you drill and tap the stripped holes, screw in the inserts which can then be locked in place. I have used these many times in my trade as a toolmaker, but do not know where you might purchase them. Must be available someplace. Hope this helps.
Paul J. Decker
02-21-2001 02:34:53
 Re: Re: Stripped Threads. in reply to popcornsteve, 02-20-2001 18:56:33
Heli-coils are your best bet and are available at most auto parts store and by mailorder at McMaster.com
Scott Green
02-21-2001 04:44:40
 Re: Re: Re: Stripped Threads. in reply to Paul J. Decker, 02-21-2001 02:34:53
My brother had the same problem. Heli coils are the way to go. Machinest told me that heli coils are stonger and hold better than new/original threads.
jimmyzz
02-20-2001 23:02:55
Caterpillar has them
John in MA
02-20-2001 21:51:29
The most popular type is a Heli-Coil. It's a little stainless spring thing that screws into your stripped hole--once you've drilled and tapped it. Worked great for me in my aluminum chainsaw. It would be even better in cast iron.
Bus Driver
02-21-2001 13:24:10
 Re: Re: Re: Stripped Threads. in reply to John in MA, 02-20-2001 21:51:29
Keen inserts and others of that type require a larger hole to be drilled than do the Helicoils. Both have important uses. Your comments indicate that the larger hole will be a problem. Sounds like the Helicoils will be best for this repair. Incidentially, follow the Helicoil instructions rather than those of a local "expert". First time I used Helicoils, the instructions said one thing and the "expert" said another. "Expert" had me drill a hole too large for the Helicoil, so I had to go with the "Keen" style. Read and follow the instructions.
