Tool Talk Discussion Forum
Removing surface rust from cast iron woodworking t
Dan 350U
01-31-2006 10:14:53
Bought some older Craftsman woodwoorking tools,and was looking for a way to clean off rust from the cast tables without scratching.I have been using OO steelwool and PB blaster,works but very slow going. Are there any buffing wheels or other proudcts that will work to polish without scratching. Thanks Dan
DanW350U
02-02-2006 05:23:28
 Re: Removing surface rust from cast iron woodworki in reply to Dan 350U, 01-31-2006 10:14:53
Thanks for the replies, I tried the Scotchbrite pads and WD40 and have gotten excellent results. I plan to try some of the other methods as soon as I get a chance to pick up some of the products. Thanks again Dan
Davis In SC
02-01-2006 19:04:08
One good product is called Barkeepers Friend... It is in a can like Ajax or Comet. Sprinkle it on the rusty area, add a few drops of water, let it sit a few minutes, then scrub with an SOS pad, or fine steel wool. I buy a lot of vintage tools, & clean them up to sell. This is the method that works best for me. I think the Barkeepers Friend has some mild Oxalic Acid in it, that dissolves the rust.
T_Bone
02-01-2006 00:42:26
Hi Dan,
Rust can removed with soaking in vinegar. Turns rust to black oxides then can be whiped away then a oil finish can be used. Depends on how deep the rust penetrated the surface determines the steps required to take the metal to the desired finished condition.
Any type of "buffing" is just a form of metal finishing and uses a grit compound to accomplish such. Each down size of grit increases the metal finish to a mirror like finish.
So if the metal was lightly pitted from rust then you can start with a 400 grit and jump up in 200 grit steps until the desired finish is obtained.
If you use a 10x maginfier then you can see just how ruff the surface is to begin with. The end view surface will look just like this ^^^^^^^^^ with each point ridge slightly lower as the surface becomes towards mirror like using a buffing compound.
Is what your actually doing is thinning the surface ridges to a very fine point to where they can be layed over on top of each other thus appear as very smooth surface to the naked eye and is why you always want to buff in the same direction until the desired finish is obtained.
A typical mirror finish is obtained with a leather buffing pad using a rouge compound suitable to the type of metal being finished, approx 1200 grit on carbon steel using red rouge.
T_Bone
J.C. IN AZ.
01-31-2006 11:17:04
220 Grit Zircon Sanding disc on your Hand Orbital Sander along with WD40 will do a very good job. Don't use a belt sander. After cleaning a light coat of Spray Laq. will give good results for a while as to prevention of Rust returning.Better yet come on out here to Ariz.[every body else is.] and bring your shiny Machine Tables with.
bradk
01-31-2006 10:56:21
Dan, Locate a ZEP industrial supply dealer & ask for "RUST ERASER".You guys won't beleive this stuff!! ~brad
Midwest redneck
01-31-2006 10:45:31
I have cleaned off surface rust from a vertical band saw with a scotch brite pad and WD-40. I dont know how rusty your table is, my idea may not work.
VaTom
01-31-2006 17:30:41
 Re: Removing surface rust from cast iron woodworki in reply to Midwest redneck, 01-31-2006 10:45:31
Your idea works very well. Best if you take a Scotchbrite red and put it on a fast orbital sander. The WD40 keeps the pad clean.
Stickler
01-31-2006 10:31:47
look for surface finishing discs. The ones i have are about 2" across and fit on a drill. They come in different "grits". They almost look like a Scotchbrite pad that sticks to the backing plate with hook & loop. Use a solvent that doesn't have silicone in it. When it's dry and white-glove clean, follow with Boeshield or paste wax (again non-silicone)
