Welding cables
Tom
02-20-2001 14:15:56
Where can you get welding cables for an old Forney welder? Thanks, Tom
Steve U.S. Alloys
02-20-2001 16:04:38
 Re: welding cables in reply to Tom, 02-20-2001 14:15:56
Do you need the male ends Tom?
Al English
02-20-2001 15:28:13
Hi Tom, Unless there is something unusual about your cables, any welding supply will have the cable you need in stock, and will cut it to length and install the appropriate terminals. If you do a lot of high current welding for long periods of time consider going one size bigger than recommended. A larger cable will be a little bulkier and slightly more expensive, but won't get as hot. Good luck...Al English
Good advise Al !.....dave#1
02-28-2001 15:42:56
 Re: Re: welding cables in reply to Al English, 02-20-2001 15:28:13
That's great info !
You da man Al !
later,dave
