Tool Talk Discussion Forum
BIG socket set
WV2cyl
01-30-2006 11:51:11
I am looking for a 1 1/2 inch drive socket set, up to 5 inch socket. Would like gov. surplus, used, or just info on buying a new set. Terry
NC Wayne
01-30-2006 18:49:39
 Re: BIG socket set in reply to WV2cyl, 01-30-2006 11:51:11
If you have a way to go with #5 splined drive (1 5/8 diameter) instead of 1 1/2 square I can hook you up with a set going from 13/16 to 4 inch along with a splined swivel and a spline to 1' square adapter. In checking out these sockets I discovered that when you get much over 3" or so most places don't keep much stock. In this case to get a 4" from APEX they are a little over $600 apiece and there is a minimum order of 12 of them. The following is a list of the sockets and their sizes. All are Apex unless marked with a CP, and those with the rust pitting are marked RD. The few marked with pitting have some shallow pits, for the most part on one side, where they had lain against a piece of cardboard that drew moisture. Here is the list ---- 13/16++7/8++15/16++1"++1-1/16++1-1/8++1-1/4CP++
1-5/16++1-3/8RD++1-7/16++1-1/2RD++1-9/16++
1-5/8CP++1-11/16++1-3/4++1-13/16++1-7/8++
1-15/16CP++2"CP++2-1/16++2-1/8++2-3/16++2-1/4++
2-5/16++2-7/16CP++2-1/2CP++2-9/16CP+2-5/8++
2-3/4++2-15/16CP++2-7/8++3"++3-1/8CP++3-3/8++
3-3/4++3-7/8++4"
The two accessories are an Apex swivel MFL-1 and the adapter is a Proto #5 spline female to 1" square male.
If your interested let me know. Wayne----- [email protected]
Glen in TX
01-30-2006 12:00:16
Try these folks:
