Tool Talk Discussion Forum
power tool cords
in sticks
01-29-2006 17:16:24
on electric drills,saws and such where cord comes out of tool there is a support or renforcing if you will,what is this called and where can you purchase these? this is for old tool,long gone from dealers books.
Slowpoke
02-01-2006 02:11:10
 Re: power tool cords in reply to in sticks, 01-29-2006 17:16:24
Consider the 3" spark plug boot with a bead around the end. Pull one off an old plug wire and use silicone spray to get the power wire thru it. Depending on the diameter of the cord, you may need to run a length of tubing thru to expand the boot, then pull the wire thru the tubing, then remove the tubing. I use brass tubing from the hobby shop. Each size slides over the next size down. About .002 between sizes. It could take some work to get the boot to fit the tool.
NcNe
01-31-2006 21:46:17
Are you looking for the entire cord or just the gromet? If you"re looking for the entire new cord, I came across a few catalogs here recently that carry them. I"ll look in the morning to see if they sell just the gromet. Hope this helps.
J.C. IN AZ.
01-30-2006 17:34:30
I am probably different than 99% of the posters here but I do not like long Cords on my Tools, and I have many. When I buy a new Corded Electric Tool, the long Cord is cut off leaving a 10" Pig Tail and a New 3 Prong 110V. Plug is attached. Long Cords are a nuisance for small breaks in the wrapping which become large breaks real fast.Most of the time I am too far from a Receptacle for the MFG. supplied Cord to reach anyway so an extension Cord is used. Works real well for me. No more winding Cords up an trying to fit them and the Tool back in the Case.
Steve Crum
01-29-2006 19:00:31
My business is abusive on cords. I fitted my inline Milwaukee grinders with the wound stainless steel "strain reliefs". These arn't cheap but neither is downtime with a bad cord.
Check at a local electical supply house. I'm thinking these are either Ideal or Hubble brand.
Ron from IL
01-30-2006 12:26:56
 Re: power tool cords in reply to Steve Crum, 01-29-2006 19:00:31
Steve,
What you are referring to are also known as "Kellum Grips" (probably manufacturer's name). They work like a Chinese finger cuff.
Ron
Steve Crum
01-30-2006 20:49:02
 Re: power tool cords in reply to Ron from IL, 01-30-2006 12:26:56
Yeah, that's what I'm talking about.
Charles (in GA)
01-29-2006 18:43:42
Its a grommet or strain relief.
Charles
Hermit
01-29-2006 18:04:49
I've had some luck using a piece of fuel hose around the wire for support in that area.
Gene Davis (Ga.)
01-29-2006 18:04:05
They are available here at the local Ace hardware store.
Tom in Central Pa.
01-29-2006 17:37:48
I can"t help you on a new part source.I get mine from a second-hand store,flea market,or auction. If I can"t buy a cord, I"ll buy a broken or as-is tool just for the cord.I always save a good cord, when I junk an old tool.
